Hi all,
I brick my lemfo watch, after that i install firmware w618_wgl.lemfo_ddr3.common.80.emmc.w.s.170306.flashand, and things get wors, now i need W618 firmware, can some one send me a link so i can try other firmware
Thank you and good day!
Hi all,
Oct 16, 2017 6:07:09 GMT 1 rbop359 said:
Hi all, I brick my lemfo watch, after that i install firmware w618_wgl.lemfo_ddr3.common.80.emmc.w.s.170306.flashand, and things get wors, now i need W618 firmware, can some one send me a link so i can try other firmware?
Hi all,
you need to be sure what is your model. you are asking for w618 and the one you flashed is w618.
Problem is the link for finow x5+ is deleted.
I found 2 firms in russia, but same thing.
BROM ERROR : S_FT_ENABLE_DRAM_FAIL (0xFC0)
I found /thread/524/bricked-finow-x5 and start reading.
FOUND THIS :
Use the scatter.txt file that you created (on search for one online) to do a read back of the stock ROM from your working phone! This will give you a ROM_0 file dump. You can flash this directly to the bricked phone using the Write Memory tab of SPFT. To get the Write Memory tab to appear, hit Control-Alt-V in SPFT. Then, go to the Window menu option in SPFT and select Write Memory. The tab will then appear. To use this tab, you must check the preloader tab on the Download tab of SPFT. And you must, of course, also have the preloader.bin file available. If you don’t have that file, just use the Read Back tab to extract it from the working phone.
AND THIS
NOW I`m waiting the seller(LEMFO), to send me the firmware.
Oct 16, 2017 16:51:14 GMT 1 rbop359 said:
I found 2 firms in russia, but same thing. BROM ERROR : S_FT_ENABLE_DRAM_FAIL (0xFC0) I found /thread/524/bricked-finow-x5 and start reading.
btw, there are two models if i’m not mistaken w618 and w616.
I have tried it and it works perfectly. It is only for Lemfo Lem5 W618. Make sure you have this model before installing it.
I was sent the Lemfo firmware.
Greetings.
Epicuros can you copy the sacrett.txt file in post, so i can check the compitability ?? I think there is something wrong.
Oct 17, 2017 5:44:02 GMT 1 rbop359 said:
Epicuros can you copy the sacrett.txt file in post, so i can check the compitability ?? I think there is u wrong.
Send
drive.google.com/file/d/0B8OHzp9lJD7XbzRqeDJLMmk1Wlk/view?usp=drivesdk
Same error masage, thank you very much epicuros, i see your new post for LEM5 firm and try with SP_Flash_Tool_exe_Windows_v5.1516.00, error message is different 4032.
I dont know what to think.Now ì`m waiting LEMFO to send me firm and instruction.
After seceral days of resurch, found thath LEM5 firmware isn`t exported properly, something with addresses is not right. My questuion is can someone export scatter file from working LEM5 W618, not from downloaded ??
Oct 22, 2017 10:02:45 GMT 1 rbop359 said:
After seceral days of resurch, found thath LEM5 firmware isn`t exported properly, something with addresses is not right. My questuion is can someone export scatter file from working LEM5 W618, not from downloaded ?? ,
For me, i ereased chip memory and now chip is clear.
seb84 can you shere your firmware files ?
send.firefox.com/download/2b5f487289/#ytjaZiLbTi6sM8z3aHtCNg
here the link, its the full firmware and also drivers and the flash tool (everything directly from lemfo, i think the flash tool has some files inside, that the version here on the forum not have)
please read instructions too.
while you have all those problems, i would reccomend, that you flash the watch one time completely new (again read the instructions on this)
select all files after loading and flash with firmware upgrade.
report back, if it helped you.
@ sonia, where can i upload this for us in the forum? i think there are files inside the fw here didn’t had
please donwload within next 24 hrs, or the link will expire
