sounds like you paired in the wrong order and that you have wifi off and lastly, that you may have wiiwatch running in the background as well
another thing just found, when connected with watch droid (before it fails suddenly) if i dial my phone from another one, when answering the sound doesnât come from the sw, but from the tiny loudspeaker from the smartphoneâŚthe one you use when putting your phone against your face, i canât talk through the sw
Hi . Uncheck the two additional connect boxes you have ticked ( not required ) . Then do this -
Settings - more - app settings - special access - notifaction access - disable watch
Restart watch . Thanks
Thanks Tim, this has fixed definetelly the connection issues, plus the bluetooth internet connection!
the remaining issue i find is that i canât talk through the watch, although i dial from the sw phone pannel, or select a contact, the only sound in/out is between phone (in the backpack) and the other person, instead sound through the watch in my wrist, any idea about it (itâs said on the net it works)
câmon you solved 2 with a single tip! hehehehe sure u can
Bluetooth calling is not possible on android 7.1 watches regardless of what you have read . Sorry
Is it a matter of android version, anything that could be modified maybe with a new/custom firmware?
It works on android 5.1 but not 7.1 . No-one has managed a way around this yet so dont hold your breath . Lots of reasons why it is not possible . Thanks
@R_Sauvalle do you find the screen unresponsive to touch sometimes? I have the 3/32 model too but itâs dang annoying right now if I tap the keyboard keys or the accept button sometimes and have to do a couple times hard to get it to register.
@jayinatlanta Aim higher with the touch area. Iâm sure theyâll fix it.
Morning . Is yours the same ? Does yours not always respond . Thanks
Mine is the same . Let me look into this
Issue reported and they are aware . A firmware update will arrive . Keep checking . Thanks
Yeah but will we have to flash the device and lose all apps and settings? Or OTA with no effect on installed metadata?
Now thats a tricky one . You wont need to flash when available just OTA update but it is recommended to do a full factory reset after update and start again .
By far the worst problem with mine is constant disconnecting of the WiFi, and of the cellular data if I have my SIM in. This is really intolerable. No apps have instant access to the Internet and I always have to go through two or three refreshes of âno network availableâ in a given app before it connects. And when the screen times out, there goes the network - so if Play Store is doing updates or something, they show âwaiting for networkâ when I turn back on the screen.
This hasnât been a problem to this extent with any of my other watches of this generation except the Zeblaze was a little sketchy. And my Data Saver is OFF just on all my other watches.
Have you got background cleaner - battery saver on ? . I am having none of these issues at all
I have modded an existing skin with Android actions on the watch face. Only for LEM10 launcher.
I have that launcher on my watch and I think clickable actions on the watchface is a good new feature.
Can anyone try? Thanks. ps: calendar is google calendar action. Not stock mediatek.
Look in clock_skin.xml for array type 100
Link: https://sites.google.com/site/tweakradje/android/kospet-hope-lite/ClockSkinRR019.zip
interesting! I was going to check out this array type so it was a great timing!
Opens up a whole new world of possibilities. Requires some android knowlegde to get the proper actions from a package though. I use âpm list packagesâ and âdumpsys package packagenameâ to get the proper actions from an adb shell. Talked to dev of new LinerSrt launcher and it will support it too.
yes, itâs not just app launching, but like you demonstrated, itâs also brightness setting, google search, weather update etc! awesome
