yep, you are most welcome:) just remember if battery power saving is on then when the screen is off it all shut off, i turned it off cos battery life is amazing and i use fully the watch. i get 15hrs at least.
Hi Sonia . Quick question . When i recieve / make a call on the watch ( no bluetooth headset ) - and listen through speaker its soooo quiet Is yours the same . I have volume on full
Pablo11,Soniah my device is getting hot in the back,i think when i use wifi and bluetooth,this is normal,i just did factory reset.
you said before thats is better to return it,if it get hot,i will see again after the reset.
the battery is draining fast too.
Sept 23, 2018 18:44:02 GMT 1leafar said: Pablo11,Soniah my device is getting hot in the back,i think when i use wifi and bluetooth,this is normal,i just did factory reset.
No heat from mine ?
thanks matte,if you dont have this problem,its most like mine is faulty,beside that i dont know if is me but the display looks a little bit wonky too and even in top center of the edge its like straight line no round line
thanks matte,if you dont this problem,its most like mine is faulty,beside that i dont know if is me but the display looks a little bit wonky too and even in top center of the edge its like straight line no round line
Mine is really wonky but living with it . GPS lock is by far the fastest i have ever seen
Sept 23, 2018 18:49:52 GMT 1leafar said: thanks matte,if you dont this problem,its most like mine is faulty,beside that i dont know if is me but the display looks a little bit wonky too and even in top center of the edge its like straight line no round line
Mine is really wonky but living with it . GPS lock is by far the fastest i have ever seen 👍
the problem is that i can feel the heat in wrist, i use to have a watch like that and i dont like it at all, its like heat pad in your wrist
I think i can use the watch as heating pad in back,for my back pain,you know after 50 and hard working,you will need this,i wish for 25, but its not a turn around. i am like the display i little bit wonky
Make sure you have the last FW, they have worked on optimisation… Also, a hot watch means that the CPU is running, that’s not normal when the screen is off.
both things that you've menationed is not right , leafar if you have the latest firmware and still happening after reset then you should replace the watch, same for you andyvishnu, the lem x is the best speaker so far i've seen i have compared it to sounds of other watches and it is quite loud in music, calls , sms and notifications.
both things that you’ve menationed is not right , leafar if you have the latest firmware and still happening after reset then you should replace the watch, same for you andyvishnu, the lem x is the best speaker so far i’ve seen i have compared it to sounds of other watches and it is quite loud in music, calls , sms and notifications.
Just reset and speaker still no different . Gets worse . Wonky screen / broken speaker
Gutted
it is a great watch, trust me get a replacement you wo’nt be sorry:)
Works great through car kit handsfree
Car kit Lem X box video game console.
did factory reset, yeah is the latest ,even turn off Wifi, still hot just a little bit,and the Bluetooth is getting crazy like ballerina. making a dispute now,I dont want to flashing. Oh great Lord Jesus., wait like two more months.
beside the battery is draining like crazy,i hope when i get it back, we have TWRP recovery and open watch project.
