I am trying to falsh again now and I have the same error as in the picture
I’ve been fighting it for a few hours and nothing
Is there a chance to save my watch ??
Sorry for my English
Dec 28, 2017 20:52:30 GMT 1 S3V3N said:
disconnected usb at 7% flash
the watch had an old firmware.
he did not see OTA know
I wanted to manually download the latest frimware
Dec 28, 2017 22:46:30 GMT 1 S3V3N said:
disconnected usb at 7% flash the watch had an old firmware. he did not see OTA know I wanted to manually download the latest frimware
I try the newest one to upload. I still have this error on the picture
yes I know, I wrote wrong. flash the latest firmware for lemfo lem5 w618. I always have the same error
the watch does not turn on right now. flashtool sees it when trying to flash. windows also sees the watch. but as I already wrote, I still have a mistake with the photo
I think we do not understand each other How should I make a backup since the watch is only seen in flashtool ?? and writes that every attempt to update the firmware ends with an error.
Dec 29, 2017 10:26:55 GMT 1 S3V3N said:
another attempt and the same
ok, I will try
Dec 29, 2017 11:15:02 GMT 1 S3V3N said:
ok, I will try
I’m sure. the battery connector wheel is written w618 v1.0
Dec 29, 2017 11:39:48 GMT 1 S3V3N said:
I'm sure. the battery connector wheel is written w618 v1.0
do you know which firmware you need?
After installing this driver PL2303 USB to Serial Driver the flash was successful
Of course, I only managed to flash x5 + w618 stock rom
strange after flash the original lemfo firmware the watch does not start
ok, flash it with the x5+ w618 stock rom not an update and if you pleased you can stay with it but if you want the lem5 pro firmware then you can flash it again with the lem5 pro firmware.do you know which firmware you need?
Dec 29, 2017 18:56:49 GMT 1 S3V3N said:Dec 29, 2017 15:30:56 GMT 1 soniasophie9697 said:
lem5 pro firmware ??
