Yes - This is how only the firmware works
for now stay with the x5+ FW and i'll check with the developers.
Ok thx
the watch went down very quickly in the watch
at this moment he completely turned off, he does not want to load and windows does not see him.
connected to usb from 1h
I’ve already dealt with this … watch the battery is charging
I did a subassembly test with the sys info program.
It turns out that the program shows that I have DDR2, is it some kind of error ??
Dec 30, 2017 14:13:02 GMT 1 S3V3N said:I've already dealt with this ... watch the battery is charging I did a subassembly test with the sys info program. It turns out that the program shows that I have DDR2, is it some kind of error ??
is this a pic of the lem5? if so it is'nt ddr2 it is the ddr3 just as the x5+
this is the photo from LEM5
why can not I make the original fw flash from lem5?
Only x5+ works
Jan 1, 2018 15:06:35 GMT 1 S3V3N said:
this is the photo from LEM5 why can not I make the original fw flash from lem5? Only x5+ works
i think the lem5 firmware on the site is not put there by us so we can't confirm it's srouce if it is from the manufacturer. the one we put is for lem5 w616 and we get it from the manufacturer itself. my suggetion is to flash it with the x5+ w618 which suits your watch till we'll get the firmware for this watch if we can not always easy to get:/
Hi there S3V3N!
Any improvements/success in this matter’s resolution?
I am stuck in the same situation, after trying firmware flash the watch doesn’t even switch on.
Any info is welcomed and appreciated.
Hi! I have the same thing!
Jan 22, 2018 7:54:25 GMT 1 paulor23 said:
Hi there S3V3N!Any improvements/success in this matter’s resolution?
have you tried the x5 firmware which suits this model? for now…
it is better to contact lemfo on their site, if you do'nt want to wait you can use the x5 model that suits your watch for now. sadly we do'nt get much info from lemfo ourselves:/
Hi! I have this fault too! Is there any way to fix it? Thanks!
Me too. Flash failed and the SP Flash tool give’s me the error 4032.
I’m trying to Download de X5+ firmware, but always the same error.
What can I do?
May 29, 2018 14:37:14 GMT 1 albior said:
Me too. Flash failed and the SP Flash tool give's me the error 4032.I’m trying to Download de X5+ firmware, but always the same error.
What can I do?
guys, you need to be sure that you have the same model as the lem5, is it the pro or not which model is it? have you tried without preloader? did you reset the watch before flashing?
Hi! I have this fault too! Is there any way to fix it? Thanks!May 29, 2018 14:37:14 GMT 1 albior said:
Me too. Flash failed and the SP Flash tool give’s me the error 4032.I’m trying to Download de X5+ firmware, but always the same error.
What can I do?
I revived the watch yesterday with the x5 air rom.
Now the touch screen doesn’t work. ¿What can I do?
I have tested the firmware of this web for lem5 and none works then. Where can I get one that works?
With this firmware:
w618_wgl.lemfo_16g128g.common.80.emmc.w.s.170911.flash
My watch its alive and works perfectly.
Thx for this great site.
May 30, 2018 16:22:38 GMT 1 albior said:
With this firmware: w618_wgl.lemfo_16g128g.common.80.emmc.w.s.170911.flash My watch its alive and works perfectly.Thx for this great site.
can you give info which watch again you have what did you do and which FW you’ve used for future users:) thanks
I have Lemfo Lem5 pro w618.
It was a problem of not booting, it stucks in logo.
Then I flashed a new firmware that bricks my watch, it was: w618_wgl.lemfo_ddr3.common.80.emmc.w.s.170306.flash
I tried flash another firmware but the Sp tool gives me the error 4032.
Reading this forum I flashed this firmware: w618_wgl.x5air_16g-2g.common.80.emmc.w.s.170718.flash and then my watch becomes alive again. But the touch screen didn’t work.
Then With this firmware: w618_wgl.lemfo_16g128g.common.80.emmc.w.s.170911.flash my watch works perfectly.
The driver that works for me was Mediatek USB Port.
I used the last Sp Flash Tools (v5.1816).
I hope this information is helpful for you.
Sorry for my english.
