Have you looked in the WatchFace Store app that comes stock on your watch?
hello, can this software be installed on lemfo lem 12 hours?
This Software is only for lem12 pro.
Hai guys, my lemfo 12 pro canât answer & make a call, any solutionâŚ
Normally when you insert a sim card you need to reboot the watch . If this doesnt work factory reset the watch and start again . The could also be a issue with your network provider
I have had problems with the gyroscope in the LEM12 PRO, and in fact all full android watches in using the app âmonectâ. Same problem for android 7 watches and the android 10 lem12 pro. Anyone know a fix for this? In the app âmonectâ and other mouse control apps, the gyro sensor isnât supported in controlling the mouse cursor. Whereas wear watches this function does work.
Lemfo Lem 12 pro measures heart rate. Is it possible to teach them how to measure blood pressure or can their sensor not?
No . Sorry
thank you for answer
I already reboot & factory reset but the watch still canât make a call or answerâŚ
It could be a problem with your country / network provider ? Have you checked . What country do you live in ?
In the watch settings go to About Watch and then Status.
Do you have an IMEI number?
No nombor in IMEI, only Unknown writing in IMEI
Malaysiaâs
If you have no imei you should return the watch to the seller.
It is unusable without any IMEI number.
It should not be sold without an IMEI number.
Did you buy from Lemfo or Banggood?
Does anybody know where I can find the charging cable for the LEM12 Pro? I lost my cable and the power bank doesnât work for some reasonâŚ
I looked at Banggood and AliExpress and didnât find anyâŚ
is the same as for Lemfo Lem4
Optimus 2 cable will work.
¥0.01 | LEMFO LEM12 LEM12 PRO Smart Watch Accessories Charging Cable Power bank Screen Protector strap for LEM12
Yes I saw that one, but they donât have the charging cable, only the USB cable. Thanks anyway
