The files are even attached to the first post of this thread
I have followed the steps, but after this steps my watch seems turns into brick. The spflash tool claimed that download finished and I tried to reconnect the battery, but it doesnât work, how can I recover it?
Are you sure you flashed the right FW for your watch ?
You can still redo it again and see if itâs still not working.
Yes I know I rooted lem t but after changing to ticwris firmware the root is gone now so please help. Also I tried the same root method again and everthing was ok but I cannot get out of twrp as soon as i choose system reboot from twrp the watch starts reboot but instead of loading and starting the watch it again goes back to twrp so please help.
Can you post a copy of the file you used to flash twrp ?..dee, dee, deeâŚ
From the official lemfo store on Aliexpress.
@zeal_kansagara you need to flash tha patched boot image from here, using same scatter file.
Ok I downloaded this and flash as you said but still not rooted
No. It wonât be.
These are the tools that you need but you still have to install Magisk zip to gain root.
Basically you flash these files but usually before you do, you copy the latest magisk zip to the watch storage and ENABLE USB DEBUGGING.
Then flash these two images with SP Flash Tool.
Power on the watch.
Then use ADB to enter recovery.
Command is âadb reboot recoveryâ
Once you enter twrp you simply flash magisk and boot to system.
Enable Wi-Fi and check magisk manager in the apps menu. Update if needed.
Thatâs it.
Ok done thank you so much. One last question how to change orientation of app from horizontal to vertical is there any app or trick?
Hi everyone. Installed TICWRIS firmware. Everything works fine. But thereâs a problem. I connected watch droid and now from whatsapp to the notification there is only vibration, and the sound signal is gone. I canât do anything. Check out please who has TICWRIS, do you have that too?
Try ROTATION CONTROL from Google Play Store
Yep play store apps work.
Or you can use accessibility options to enable auto rotation - I would think
You would need to use settings search apk to find it thoughâŚ
So @Aylwin_Chan suggestion is easier
I tryed rotation control app i read help section inside app there are many options available but inorder to activate any of that option we need notification panel like smartphone but in lemfo ticwris there is no notification panel like smartphone so how to access this option?
So pull down menu is not working?
Or swipe right from clock screen?
You can just use settings search and enable rotation in accessibility settings
Settings Search_v1.0_apkpure.com.apk (136.0 KB)
Both the menu are working pull down and swipe right but non of them has option of rotation also I tryed the app you gave setting search but app is not usefull as when I open the app and click on accessibility it just open normal inbuilt accessibility setting and inside that also there is no option of rotation is there any other way to do this?
I will have a look and see if I can find rotation but I am very surprised that accessibility does not have the option.
I just tried this one: https://play.google.com/store/apps/details?id=jp.snowlife01.android.rotationcontrol
To change the rotation from the notification bar doesnât work with this one either, but in the app you can choose a rotation for each app you have installed. the free version only lasts two days though
yes this is working we want something like this only but permanently free of cost.
Did you try accessibility options?
Just curious
