KW88 Firmware
Hello,
Can someone send me the link to the new Firmware version please?
Best regards.
djedu9999 make sure to read carefully the instruction on what to do!!
/thread/1751/kw88-512-call-firmware-update
Nov 20, 2017 17:53:37 GMT 1 soniasophie9697 said:djedu9999
ügyeljen arra, hogy alaposan olvassa el az utasításokat, hogy mit tegyen!
Sziasztok!
Érdeklődni szeretnék,hogy a KW88-ba honnan,és hogyan tudnám belerakni,a magyar nyelvet,jelenleg a legújabb firemware van rajta,de abban sem volt magyar nyelv!
Köszönettel:pocok
Sziasztok!
Köszönettel:pocok
in the latest firmware there is’nt hungarian?
Sajnos,én nem találtam,de megnézem,mégegyszer!
Esetleg valaki be tudná nekem linkelni,a legújabb firemware-t,KW88-hoz,nekem 20171111-van!
this one is the latest.
I downloaded the updates I used SP_Flash_Tool_v5.1712_Win and I have bugs
zapodaj.net/ca460c1f49fe7.jpg.html
zapodaj.net/0f81664da0212.jpg.html
the watch does not start
Jan 6, 2018 22:07:42 GMT 1 kosor123 said:
I downloaded the updates I used SP_Flash_Tool_v5.1712_Win and I have bugs zapodaj.net/ca460c1f49fe7.jpg.html
it seems connection problem and now the watch is’nt recognized by sp.f.tool. flash it with the original firmware and then do the upgrade again just make sure the cable is in it place. does the computer still recognize the watch.
The computer does not recognize the USB device
Where did you get the original flash?
Jan 7, 2018 10:55:47 GMT 1 kosor123 said:
The computer does not recognize the USB device Where did you get the original flash?
/thread/18/kw88-kw98-kw99-firmware-thread
Thank you very much.
The computer is not a watch, so it’s possible to upload the software?
Is there a way to go back?
Jan 7, 2018 15:28:12 GMT 1 kosor123 said:
Thank you very much. The computer is not a watch, so it's possible to upload the software? Is there a way to go back?
you do'nt need the watch to be on that the sp flash tool see it, download the firmware as long it is the stock you can always go back:) flash the stock firmware and if everything goes well flash the one that need to be upgraded.
I downloaded the software for KW88 and there are several directories in it.
I know what’s next Can you explain it to me step by step?
KW88 20161104
KW88 20161215
KW88_CS1_B 20160707
Please
I have the same as him, the watch does not react
I’ve downloaded:
Using tutorial:
The preloader in de Firmware is called “preloader_KW88_B_GSM_PHT.bin” Do I need to check the preloader?
Thanks in advance
Jan 7, 2018 16:52:38 GMT 1 kosor123 said:
I downloaded the software for KW88 and there are several directories in it. I know what's next Can you explain it to me step by step?
KW88 20161104
KW88 20161215
KW88_CS1_B 20160707
Please
do you need help in which firmware to use?
Jan 7, 2018 20:32:38 GMT 1 rikkio said:
I’ve downloaded:
Using tutorial:
Thanks in advance
preloader will be marked if it is the stock firmware for your watch and it is not the bt calls app inlucded then you use download only and not upgrade.
Sziasztok!
Még mindig ilyen probléma van, hogy a győzelem 10-es futtató gépem, nem látja az órát, hiba üzenetként írja, hogy "hiba lépett fel a készülékbe, és nem ismeri fel
Jan 11, 2018 15:19:05 GMT 1 pocok said:
Sziasztok! Még mindig ilyen probléma van, hogy a győzelem 10-es futtató gépem, nem látja az órát, hiba üzenetként írja, hogy "hiba lépett fel a készülékbe, és nem ismeri fel !
sorry?
Hello, I have the same problem with upgrading to KW99_CS1_B_20171111.
Through installation process the watch disconnect him self from computer and brick.
After a lot of attempts including re-installation of VCOM DRIVERS, downloading of new versions of SP tools and etc. I have success to downgrade to older version and watch became alive again.
So I start to upgrade again to KW99_CS1_B_20171111. This time with success.
But was my disappointing from KW99_CS1_B_20171111, the watch disconnect and connect again to phone on every 15-20-40 seconds. So I downgrade to KW88_CS1_B_HM005_20170728. With this firmware version and latest version of watch droid app, the watch work perfect. The only thing I do not like in Watch droid app is that you can not pick up incoming call from watch, only can discard. WiiWatch app, sucks, I do not receive notification for incoming calls.
Jan 17, 2018 9:28:52 GMT 1 fonzy said:
there are also m2d and swapp link:)
