KW88 Firmware
Jan 17, 2018 15:08:11 GMT 1 soniasophie9697 said:
Jan 17, 2018 9:28:52 GMT 1 fonzy said:
there are also m2d and swapp link:)
I Can't find swapp link. Can you show link for it?
apkpure.com/swapp-link/com.preiss.swapps.link
you need to download to both devices and choose one sender and one reciever.
I Can’t find swapp link. Can you show link for it?
Unfortunately m2d app can not connect with watch.
Swapp link is good for me, too much effort to connect, setup and use. I personaly don’'t like it. May be for some one else will be fine.
m2d can be used by 3g, wifi and bt. you need the bt app to connect both devices but also you can use as i said 3g and wifi for notifications
play.google.com/store/apps/details?id=com.pacosal.m2d.manager&hl=en
I’m using Parallels Desktop Windows 10 on a Mac in order to do this, but the device is not recognized by the flash tool, and I get an error:
"S_COM_PORT_OPEN_FAIL (1013)
[COM] Failed to open COM port.
I have installed the drivers, yet I don’t see com ports in the device manager. Any ideas?
Feb 8, 2018 23:03:44 GMT 1 charliev said:
I'm using Parallels Desktop Windows 10 on a Mac in order to do this, but the device is not recognized by the flash tool, and I get an error:
did you make sure that mtp usb are installed too? on other PCs the watch is recognized?
I know the problem: Windows 10 on Parallels Desktop for Mac just simply doesn’t play with the com ports. The flash tool won’t detect the watch when it’s off. I installed Windows 7 and also installed/uninstalled the mtp drivers and the flash tool detected the watch. I successfully updated the firmware after that…thanks for your quick answer though…
Success, I had a black screen and I could not upload the software.
The watch was always disconnected.
I undressed the watch and cleaned the contacts. It helped.
I played soft
I have uploaded 20171111
In the information I have:
  • Android 5.1
  • Security fix level 2016-06-01
    -Band version MOLY, WR8,W1449,MD.WG.MP.V6.P17,2016/07/29
    -Kernel version 3.10.72 2017
    -Compilation number KW88_CS1_B_GSM_PHT_2 0171111
Is it supposed to be like this? because it’s 2016 ?
