KW88 - Firmware - KW88KW88_CS1_NHH_B_GSM_PHT_20180625
Has someone tried this version?
www.king-wear.com/support/download
The legend at said: For New Hardware Updated since 2018/08
I’ve flash it but I just got a black screen…
Oct 2, 2018 1:23:24 GMT 1 dan1980 said:
any firmware that we publish on our site we make sure it is ok, you might flashed the wrong firmware on your watch there are two type of kw88.
you’ll find the right one here on our forum, if you are’nt sure tag me and i link you to it.
which one is the right firmware for kw88 Pro?
i just noticed that yours is the pro, none of the ones are here are for this watch, let me check if we can get.
GUYS, only use firmware that is published on this forum cos we make sure they are tested (if we have the watch).
link not work for firmware download
danyrow
which link?
Oct 30, 2018 6:39:33 GMT 1 soniasophie9697 said:danyrow
which link?
tread number one dan1980
i know it’s not related with described problem here, but my KW88 is using KW88KW88_CS1_NHH_B_GSM_PHT_20180625 + universal launched new gen 2.6.5 + watch droid… and all work stable and well
no issues
what?
I’m going to www.king-wear.com/support/download. I click KW88, a new blank page opens.
It does not charge anything
Nov 6, 2018 9:53:56 GMT 1 kosor123 said:
I'm going to www.king-wear.com/support/download. I click KW88, a new blank page opens. It does not charge anything
why are'nt you downloading from our firmware section?
I am asking you to indicate the link.
The links I have found are directed to:
tone, being polite will give you more replies! which watch do you have? kw88 pro, kw88 and which there are 2 models of this watch and ALWAYS check our firmware section for new updates:  /board/62/kingwear-firmware
I am removing any firmware not checked by us because my message box is now getting full of people with bricked KW88s and it is getting ridiculous.
Please do not post firmware from anywhere else and if you need something - ask - I will get it.
I just noticed you posted the kw88 pro firmware. It is “KW88Pro_V1.3_B_20180713”
How come the one that came with my watch is version 1.1 with the date 20180804? It makes no sense that a higher version has an older date. Is there any reason??
I’m sorry, I didn’t mean to offend anyone.
I have KW88
kosor123
sadly it seems there are not even 2 version of this watch but four firmwares versions so we need to be careful. when did you buy the watch? can you upload device info? baseband…
The downloads from the Kingwear website only give me a blank page. Is there any download available at the moment?
I am hoping to find some firmware updates which will reduce the intensive battery drainage.
Hi so my first question: where can I find a good working and not bricking version of the latst firmware for the KW88? The Kingwear website seems to be empty as nothing can be downloaded from there.
