KW88 - Firmware - KW88KW88_CS1_NHH_B_GSM_PHT_20180625
dhooren
/board/62/kingwear-firmware
be careful you need to be sure about your model, can you upload device info and firmeware info?
Nov 8, 2018 4:39:55 GMT 1 soniasophie9697 said:kosor123
sadly it seems there are not even 2 version of this watch but for firmwares versions so we need to be careful. when did you buy the watch? can you upload device info? baseband…
I bought Jun 12 2017  - KINGWEAR KW88 1.39-inch MTK6580 Quad Core 1.3GHZ Android 5.1 3G
can you upload also the device info in about device, so we know which firmware it has and which firmware you can use.
Oof course:
  • MOLY.WR8.W1449.MD.WG.MP.V6.P17, 2016/07/29
  • KERNAL 3.10.72 NOV 11 2017
  • KW88_CS1_B_GSM_PHT_2 0171111
Nov 15, 2018 9:46:26 GMT 1 kosor123 said:
Oof course: - MOLY.WR8.W1449.MD.WG.MP.V6.P17, 2016/07/29 - KERNAL 3.10.72 NOV 11 2017 - KW88_CS1_B_GSM_PHT_2 0171111
this is the latest version, you can find it in our section for kingwear watches. remember to use upgrade and the latest sp f.tool.
thank you very much
у меня проблема подключение с телефона к часам
скачал по штрих коду приложение wiiwatch и он включается и отключается, версия kw88_cs1_b_gsm_pht_20171111
How can I enter our software section to be able to download the firmware to the KW88 Pro watch?
I can not find the link anywhere
@Andrzej_Bonczar, here you go (I’m not sure whether the firmware is available, but this is the place to look):
https://discourse.fullandroidwatch.com/c/kingwear-allcall-products/kingwear-firmware
please i really need the original kingwear kw88 firmware
I shared the original firmware with you.
If the firmware with NHH is not working, then you have a very old watch indeed.
Maybe, after you have flashed the NHH version you can share a screen shot?
