KW 88 screen turned up to down
Oct 11, 2018 14:24:38 GMT 1 elobayor said:
Thanks in advance, I appreciate this.
Hi mate,
I got this for you to test…
But - flashing this is at your own risk. I do not have a KW88 with this screen type so I could not test it.
It is official KingWear firmware - I just cannot test it.
The first time you flash this, try the “Download Only” mode in the SP Flash tool.
If your KW88 boots up with the correct screen position you can just factory reset and should be good from then on.
If you do that and the screen is still upside down or it behaves strange in any way - flash again using the “Firmware Upgrade” option in the flash tool.
Download here drive.google.com/file/d/1tZoIMyTVwy5wfXYDUULadrW3-POJ_UhZ/view?usp=sharing
I say again - flashing this is at your own risk. I do not have a KW88 with this screen type so I could not test it.
Good luck.
Should I flash preloader?
Nothing changed.
Oct 12, 2018 19:28:16 GMT 1 elobayor said:
Nothing changed.
flashing went well?
Yes
Oct 13, 2018 6:05:42 GMT 1 elobayor said:
Yes
Did you use the firmware upgrade option in SP Flash Tools? If you have and it is still upside down - I really don't know what to suggest... But I will let KingWear know again.
Yes
Ok, I am getting a new version for you to test if that did not work
Yes, I did what you said. First flashed only using download only, then (when nothing changed) using firmware upgrade.
Ok, I'll send you a link to the new one to try as soon as I can upload it.
Ok, we have prepared another test firmware for you to try.
I spoke to the Firmware team today and they recommend this test firmware.
I hope this works for you
Download
drive.google.com/file/d/1xRC5eVgGbF1vr7alHz0nebLUcR0QI0oO/view?usp=sharing
‘MPT changed for the ROM; it must be downloaded. Please select “Format All + Download” scene and try again’
What should I do?
‘PMT changed or the ROM; it must be downloaded. Please select “Format All + Download” scene and try again’
What shoul I do?
Oct 13, 2018 15:25:27 GMT 1 elobayor said:
'PMT changed or the ROM; it must be downloaded. Please select "Format All + Download" scene and try again'
What shoul I do?
do’nt do that thatwill arese your imei and you wo’nt be able to restore it. what did you try to do when you got this msg?
Download only.
Oct 13, 2018 11:42:01 GMT 1 RASC Moderators said:
Download
Oct 13, 2018 16:13:26 GMT 1 elobayor said:
Download only.
have you tried with the latest firmware on this thread? the one i linked here?
That happened when I tried to flash that exact firmware. There was nothing like that ever before with earlier firmwares.
So after change to firmware updAte, the flashing went all ok, but now watch does not turn on and even when I connect to charger nothing is shown on screen.
flashing went well and now the watch is'nt turning on? try to connect to pc and see if detects the watch especially via sp f.tool.
There is a sound of connected device and disconnected device and it repeats all the time watch is connected to pc.
what about sp f.tool?
