Aug 7, 2018 9:01:08 GMT 1gameunit said: Yeah, i guess it did. it had to be lemfo firmware since the watch shows up as a usb device as soon as i connect it to my pc.
Yep,
I am still surprised that using the firmware upgrade option in SP Tools with the new firmware does not fix the problem Same here, trying everything. Searching all over the internet. Even some of your old posts from 2016. . Normally a firmware upgrade should correct everything. Just not in my case. lol
So I’m another one with the brand new kw88 from aliexpress with the flipped screen and none of firmwares works.
Do you think any app turning the screen would help? Problem is with connecting to Gooogle Play to download anything (need to log in what is almost impossible with screen flipped)
When I bought it everything was ok except connecting to smartphone. Then I’ve flashed it to 20171111 version and the screen is flipped. Which firmware is for KW88Pro?
Hmm, ok
The fact that you tried the other version and it doesn't work means you almost certainly have a HEHUI screen.
Did you you check on the KingWear website? They have the firmware for the new screen on the KW88.
I have not uploaded it yet so it will be quicker for you to get it from there.
Oct 11, 2018 12:05:29 GMT 1elobayor said: Their site does not work on any on my browsers... When I go to support/download and click download button nothing happens.
Ok, I will upload it but I have to warn you that my internet connection is like dial up speed
That's what I get for living in the mountains 😂
