Same in Greece, no OTA update here. I tried yesterday, after i saw posts for battery increasement on 2.0 version. I will flash it today.
Ok
@Giorgos_Tsarouchas
@Vinzie
Do you both have 3+32gb watches?
Or Prime SE?
If you have Prime SE or 1+16gb version you cannot flash this and there is no v2.0 for that watch.
If you have the correct 3+32 version you can try changing your location to Australia and reboot and then check update.
Otherwise just flash the firmware I posted in the top post using a Windows pc or laptop.
Hi
I have not. I am looking thru forum on how to do this. Can you point me to any guidelines i can follow
If you have the 3+32 version and you have downloaded the firmware then you can use the same tools and guidelines posted here (just donāt use that Genesis firmware)
I have the 3gb+32gb version. I will flash it, i have done this again
Cool. All good then
I have prime se. So looks like its as good as it will get for me⦠Kospet should let us know you cant upgrade firmware on prime se.
Enjoy the firmware of the SE. The SE clockskin engine works fully. The Prime 3/32 only up to version 1.6.
Iāve been updating to The new firmwire OTA and after that my heartrate monitor, pedometer stop working and the battery time has been cut to half.
Hi,try a factory reset after flashing.
thks
because the OTA is only from version 1.7b, you need to flash manually from 1.8b
Yeah, factory reset, or flash the v2.0 firmware manually using the firmware upgrade option in the flash tool.
Hello.
I have installed the firmware 2.0 but Playstore doesnāt work since yesterday, it say āerreur serveurā
Have you an idea ?
@pablo11 good afternoon. You say that thereās no 2.0V for Prime SE ? Does it means that the watch stuck on 1.8v ? With batery draining fast ?
I am waiting for a Prime SE.
does are bad news
@SERZAO The Prime SE firmware is excellent. It is so good that I did not notice any difference in daily use. In fact, the SEās battery held up even better in my tests.
@G1NT0N1C many thanks for the info. You answered part of my doubt, the battery part. In terms of firmware, will i be able do upgrade firmware untill what version ? I mean with OTA and flashing ? Thank you
@Vinzie happen to me also, but i guess i just look at the price, anyway iāll face it as a Entrance smartwatch for me and if i explore the SE at 100% iāll Just have to upgrade
In fact, the main differences between the different firmware versions are in extended language libraries (version 2.0 has an improved layout for Arabic language). Little has changed in terms of functions.
As of version 1.7B, important functions of the Clockskin engine have been lost in the Prime Firmware. This is the reason why I use 1.6B on my Prime version.
The SE does not have this problem, the Clockskin engine works without restrictions.
There are currently no OTA updates for the SE. I suspect there will be some at some point. Then you can also enjoy an improved layout for Arabic language at SE.
@G1NT0N1C i want to thanks and congratulate all a of you guys from the staff, for the dedication you have.
Knowing that SE dont upgrade was a huge punchā¦and at the same time will let me enjoy untill i am tired
Learning a lot here.
ONCE AGAIN MANY THANKS DREAM TEAM
You are welcome.
