I read some information about charging and people say that if you want your battery live longer you must charge till 80% and you must not let battery drop below 20% if it’s not hard for you ppl can you tell your opinion pls
I would take ur opinion but i would usually chage it till 97% then till 15% ill keep cuz u dont want to make the pluging and remove of the charge a lot u wanna minimize it so its better to save that i agree with you but this is my opinion
I charge watch once daily
is it a lot?
No thats just perfect if you use it the whole day .
And try to avoid leaving on charge longer than required ( overnight )
My main problem is to charge to 100% or better 80?
if 80% - 20% lasts the whole day then I would do it that way
Actually when I don’t use it I put it on power save mode and when I go out I just turn power save mode off
Sometimes 2-3 days watch are on save mode LOL
I dont think you should be using a different charger
because it might destroy the battery.unless the other charger also has the same volt power
Very good point . This is a easy way of ruining the P2
Its just like using an apple charger to charge your samsung both have different power volts.i recomment to ise the original charger
well, the prime 2 doesn’t come with a power brick, so…
I use either an old sony power brick or my laptop when I charge my prime 2. Wouldn’t mind using an apple charger on a samsung phone either, as long as we’re not talking about trying to use the lightning cable.
Sometimes when prime 2 is on power save mode for a long time after that when I turn off I can’t use sim card says insert sim card but when I reboot it works fine.
So the question is:Is it ok if watch are on power save mode for a long time?
Yes, it is ok. No problem at all.
Thnx for respond
By the way when I was charging prime 2 with domino dm368 charging was pretty slow
But it’s original are pretty fast charging
Did you use a different cable? I don’t recommend this. The polarity of the Prime2’s charging cable is different from most other watches. The risk of damage is high.
I directly connect to a 5 volt usb pulugs u can such extention
1 more thing which is right charge while in save mode or better charge when power save mode is off?
It doesn’t matter.
