I dont know maybe I am asking too much but it’s because because I am not rich to buy another one if watch will die LOL
But you know there is difference between charging in power save mode and and standart in power save mode charging Is going pretty slow
Dont think it matters but if u really want precautions then turn off power save and charge in the standard way
Heyhey…a lithium-ion akku has no noteworthy memory effect. You can easily charge such akkus at any time without the akku losing capacity.
Enjoy Your day. Hermann Schulze
So you mean there no need to limit on charging so I can freely charge up to 100%
GM.
Yes You can recharge Li-Io starting f. e. with 20% and/or 40%, but You should avoid a permanent Charging above 100%. You cannot do that with NiMH.
Regards Hermann Schulze
Me usually charge at 20 pr 50% and when it hit 100% me immediately removing from cable.
Am I doing right or I shouldn’t charge till 100% that’s what I want to know
Heyhey…A soon Your Watch with LiIo-Akku shows 100%, stay on Charging for another 15 minutes or You messure the drain. If there is nomore fluent drain You can disconnect the charger.
I have 4 Full Android Smartwatches in daily use without any Charging-Problems.
Kind regards Hermann Schulze
