got my watch a week and very satisfied since today I’m having loudspeaker issues, when someone calls me I hardly hear anything the volume is maxed out, tried 50 % volume can’t hear anything the sound is cracking too, using a BT set the sound is marvellous.
if this cant be solved do i have to issue a claim to Bang good or here
Initially the loudspeaker in my watch was also behaving similar in that it wasn’t loud enough. Over time it has improved a lot and I can’t really explain it. Perhaps it makes sense to install the latest firmware version (27 jan 2019)
The loudspeaker was very quiet on my watch as well. I downloaded a volume booster, and it worked a little bit to some extent, but anything other than voice would get distorted with the increased volume. Speaker wasn’t meant really to play music in a semi-loud environment. I have had great success pairing a bluetooth headset and listening to podcasts that way.
These watches seem to have different problem’s with everyone, Because my speaker works great . I can even hear it well with out head phones while cycling every day. In fact I have trouble getting it to pair with headphones. really i WISH i wouldn’t have bought it
turn off your watch switch on again try different headphones i got 3 2/3 connect instantly and are working great dont ask me why the 3rd headphone doesnt work
GOT LOUDSPEAKER PROBLEMS AGAIN HARDLY HEAR ANYTHING. I’m living in a tropical country Thailand, The thing is the loudspeaker is in the wrong position
it should be on the side of the watch or between the watch lugs, coz the loudspeaker is at the bottom when I go running the sweat is destroying the loudspeaker this is a major production flaw, so lets hope that kospet take note of it and replace the loudspeaker
Mar 5, 2019 16:26:50 GMTglitterfart said: GOT LOUDSPEAKER PROBLEMS AGAIN HARDLY HEAR ANYTHING. I'm living in a tropical country Thailand, The thing is the loudspeaker is in the wrong position
The speaker sits opposite of the buttons. Imho the best possible position.
They are too low they are at the bottom of the watch not on the side.The speakers are always in touch with the skin and in my case sweaty skin, today in Thailand only 38 degrees
Mar 6, 2019 12:02:29 GMTjockyw2001 said: I still haven't bothered to disassemble my Kospet, but I am curious if some kind of speaker mod is possible
I don't think adding a bigger or better speaker will make a difference. More to do with the amplification circuit that I am sure is lackluster in this unit.
Mar 7, 2019 9:51:04 GMT 2glitterfart said: If this issue cant be solved I think to make a video and address Bang good and kospet what they can do about it
have you tried to use air spray the kind that is used to clean PCs?
My Optimus pro volume fades to low and no sound. I found that opening the SIM card door and closing it slightly while playing music is a temporary fix. Leaving the sim door and screw loose is not smart but my problem don’t happen as much until I tighten it. I think the speaker is getting vacuum locked because of no pressure equalization hole.
