Dear friends!
My Kospet Hope watch can not find the GPS signal.
I have installed a gps test application but can’t find a satellite.
Could you tell me,what should I do?
Pifi
Dear friends!
Pifi
Jan 14, 2019 22:05:28 GMT 1 pifi said:
Dear friends! My Kospet Hope watch can not find the GPS signal.I have installed a gps test application but can’t find a satellite.
Pifi
Hi, i have the same problem…no fix.
You found a solution? I not:(
Jan 24, 2019 7:35:52 GMT 1 iandhope said:
Hi, i have the same problem...no fix. . You found a solution? I not:(
Good morning, last firmware, original launcher… A reset would be hard work again:). But ok, i try it. With google maps i get no location with gps only. Gps test app shows me 22 views, but no fix.
Greatings
Jan 24, 2019 9:36:43 GMT 1 iandhope said:
Good morning, last firmware, original launcher... A reset would be hard work again:). But ok, i try it. With google maps i get no location with gps only. Gps test app shows me 22 views, but no fix. . Greatings
Hi, yes … same same. Factory resset was no solution too. Wifi mac i dont no/i no understand:)
Greatings
A new version of firmware is coming to fix the Mac address changing on reboot.
The GPS problem seems to be very random.
I will talk to Kospet about it.
Jan 25, 2019 5:50:04 GMT pablo11 said:
A new version of firmware is coming to fix the Mac address changing on reboot.The GPS problem seems to be very random.
I’m desperate. The clock could be very good if the gps were working. But some important applications don’t work at all. But I’ve tried everything.
I have the same problem.
The clock has the latest firmware and the factory reset was not a solution.
Can not lock gps.
Please understand that it is currently Chinese new year and they will be on holiday for a a couple of weeks.
Some others in the main support thread here have managed to fix this problem on their Hope watches.
Jan 31, 2019 22:10:08 GMT hjor said:
I have the same problem. The clock has the latest firmware and the factory reset was not a solution. Can not lock gps.
Pifi
Jan 24, 2019 14:25:30 GMT gabrikira said:Jan 24, 2019 8:36:43 GMT iandhope said:
hello, i have the same problem, i just factory reset the watch for the third time and with GPS only activated, google maps get no location too, GPS status apk shows 17-22 satellites on view but no lock. I already ordered the data cable to see if i can repair it with root. Ah, i´ve got the problem with Wifi Mac changing every time Wifi connect/disconnect. greetings
Dear friends!
You found a solution? I not:(Jan 24, 2019 14:25:30 GMT gabrikira said:
hello, i have the same problem, i just factory reset the watch for the third time and with GPS only activated, google maps get no location too, GPS status apk shows 17-22 satellites on view but no lock. I already ordered the data cable to see if i can repair it with root. Ah, i´ve got the problem with Wifi Mac changing every time Wifi connect/disconnect. greetingsJan 31, 2019 22:10:08 GMT hjor said:
Can not lock gps.
guys, when you say gps do'nt work, have you tried outside first? i get a lock very fast on my Hope and no issue and mine is not up to date, which app are you using? with google map it works but not with any but not every gps test app is good.
Just thought we would let u know
Regards
Tim and Pierce ( he says hi
Thanks for this feedback mate.
This is very constructive and gives me something to work with.
I’ll let you know how I get on with it.
Pablo
Feb 22, 2019 0:48:08 GMT pablo11 said:Tim And Pierce Collins
Pablo
I know why the problem exists but fixing it will be tricky.
It’s all due to the GPS config being set up for China.
To change it requires root access or an adjustable config which is what I will be working on.
This is why it takes so long to re-establish the connection once you have turned it off and on again.
must be very random got mine 2 days and used gps turn by turn worked great
