Here is my ClockSkin - JN_Pentagon
Build with WFD for #stocklauncher#android
Features: Hours, Minutes, Seconds, Day, Week Day, Month, Weather, Steps, Heart Rate, Battery Level.
Free to use for everyone in this community… Do not re-share. Download Link: https://drive.google.com/file/d/1ouw7WofjhBgpEw0_hjiiZ8lgkGsw0653/view?usp=sharing
@Joao_Nascimento Congrats, Sir! Your productivity is amazing! Just a minor detail: I came to realize that some of your watchfaces tend to show some circular sub-dials/arc meters wrongly in Kospet Hope running SL. That beig the case with this one (battery metter arc shows on the left, near the end of step counter) and others that I can’t recall right now (I remember this hapenning with a IWC color set of faces, among others).
Anyway, do not take this as a complaint at all, please! Your work is much appreciated!
I just uninstalled the ones presenting this issue and moved on (wouldn’t even bother to tell you), but as I experienced it right now, thought it would worth a mention.
@brunops1, thanks for your words. This face should work ok with Stocklaucher. I have no idea the reason why it doesn’t work on Kospet, maybe @G1NT0N1C or @Eric_Crochemore can help!
The newer face engines offer many new features. The functionality of the battery percentage function has also been changed. This display is now always shown centered. This is actually good as it looks better. Unfortunately, many faces have used the last and middle digits to represent images. This no longer works because these digits are no longer in the same place at all times. The faces that are affected by this must be changed in order to work for the new face engines. I’ll create a guide when I find some time.
@Joao_Nascimento , I’m sorry, but job obligations kept me away for a while. Thanks a lot for your concern (and @G1NT0N1C help too). I’ll give it a try later tonight. Much respect for this community.
Unfortunately, something is not good there should be 101 lines in digital2xml. otherwise it uses a rounding rule. For example, the display jumps from 77% to 88% after 80-88% perfect from%88 to 99%
PRIME.
I just finished testing. The test works well.
There are only 10 lines in what you did. But it bounces as I described. What I uploaded has 101 lines and is good with that
