Yes, I can watch a YouTube video in one of the digits
@gyuri Youâre right, I stopped thinking a little too early. I thought that 10 lines in digital2 are sufficient. But you are correct, this leads to a deviation of 1% in some cases. Therefore your solution is the better one.
You have done a good thingâ˘!
@Joao_Nascimento the face I have linked is fixed.
Thanks.
Yes that is right.
@G1NT0N1C it seems worthwhile to sleep one because of such problems. It turned out that 10 lines were few and 101 lines were many and unnecessary. The best solution is 11 rows. The first line of AT61 and AT63 is the âzero pointâ. So if there are 10 lines it divides the 100% into 9 sections. And with line 11 we achieve the same as with line (10X10)+1. That is why it is unnecessary to write so muchor use Ctrl + C, Ctrl + V
Hi Joao,
I really liked your last Clockskin. However I found a problem when I ran it on the watch.
Whe I select the image (small picture) it looks OK however when It takes the full frame, the battery arc is misplaced (large picture)
Hi Joao,
I tried downloading the new engine and it caused a freeze. (There was no dial display and no way to get anywhere in the watch).
I had to connect via ADB in order to remove it.
Whatâs your watch and your firmware version?
Microwear H8
Android 7.1.1
Kernel 4.4.22
Build Number: NJY_Mo4_CN_4G_V2.3_20190326-1409
Have you tried the standard version?
Yes, the standard version runs OK but the colorful red to green arc representing the Battery is in the middle of the watch (see 2nd attachment above)
in the watch face âselection modeâ (with the small watch-face picture) the arc is in the right place
(see 1st attachment above)
Ok, i checked it out. The clockskin engine of your watch is the older version, which means that it cannot use the new array types. However, in this case the old version does not work either, as the clockskin engine of the H2 differs from most of the others in some respects. You could fix it by opening that watch face in WFD and moving all the elements of the battery 200 px to the right.
Hi Joao,
Thanks for your help!
I changed the following lines:
digital1.xml
14
-400
0
digital2.xml
14
digital3.xml
14
400
0
to:
<drawable>
<name>digital1.xml</name>
<arraytype>14</arraytype>
<centerX>600</centerX>
<centerY>0</centerY>
</drawable>
<drawable>
<name>digital2.xml</name>
</drawable>
<drawable>
<name>digital3.xml</name>
</drawable>
and now itâs OK (I tried other values like 300, 400 which didnât help)
Excellent work as always! I want a celsius value for the weather picture! If it can be solved, thank you very much !!!
Thanks. Temperature? not in this one , sorry.
