4 posts were merged into an existing topic: International Firmware [Beta] (LEM12Pro, LEM14, LEM15, Prime2)
at the beginning, thank you for a very good soft for my lem12pro, keep it up. If you can change something, you could do something like after connecting the cable to the watch, the question was what you want to do, just loading or transferring files
Good morning everyone. I have the following question:
Can I install in case I need this version directly from the sd of the clock after having installed any of the versions 1.0.or.1.1? Or do I need to do it with the Flashing Tools?
Z32-LEM12pro-V06_20201102.zip
@WolfNight
No you can’t.
That is firmware that needs flash tools to install it.
I have installed version V1.0, and later V1.1. I would just like to report that my device gets too hot with these versions. Especially when charging the battery. Thank you for your quick response and all your work.
Did you perform a factory reset after installing? This should solve your problem.
At the beginning is getting hot. After you played and installed all the updates, is back to normal.
Wait and see.
Quick question about the v1.2 beta firmware. You disabled 2 fast and 2 slow cores. Is this in the kernel, or just in the SMP settings. I was wondering if we can enable them if we wanted to do something intensive (like watching our battery drop
v1.1 working beautifully on my watch - kudos.
That have been changed to two performance cores only, from some benchmark testing it seems like this has even a slight advantage in performance.
But that is probably due to the throttling caused by the thermal discharge of all 8 cores.
Yep - the simple reason we are looking at using less cores is battery performance and heat reduction.
8 cores sounds great but is seriously not needed for a smart watch and leads to unrealistic use cases.
I have serious concerns about people expecting to be able to use a smart watch as a tablet or flagship mobile phone…
Like gaming, watching streaming video for ages and long “face time” conversations etc.
I worry that the term Smart Watch is becoming lost and expectations are growing out of control…
It is a watch with smarts intended for light coms and some monitoring - right?
Not a HPC disguised as a watch
@pablo11 - you are of course correct, however you get weird people (like me) who do things like install termux and ashphalt 8, connect a bluetooth keyboard and joystick, use miracast to a big tv and love to lord it over the apple watch people
Seriously though, I did actually do this. Battery life was reported in minutes, not hours though… For realistic use, disabling the big cores to preserve battery is perfectly reasonable. Who really needs an octocore watch?
EDIT: I do occasionally do teams video calls on my watch when I am out and about. It actually works surprisingly well.
Yep - not just you mate
You’d be surprised, lol
Yep - together with Wiiteer, we are looking at making it a good user experience for all users.
Users that want a smart watch - not a processing plant
So it’s about finding that balance of fluid user interface whilst retaining good battery life.
these little gadgets are already extremely powerful devices.
but still they are limited to physics laws. People should keep that in mind.
In my opinion it doesn´t need higher performance. The sold features should be working (HR-Sensor…) and the FW should be more polished (big progress with FAW-FW) to gain acceptance and become useable for everyone that is not nerd.
It is a great outcome indeed.
We will publish something soon about this whole project and what happens next.
We are extremely happy with the response from everyone and how people are happy to get involved.
Thanks to everyone for their efforts and fingers crossed that we can make a difference.
Apologies going off topic yesterday.
Thread cleaned…
Can this be installed on lem 12
This firmware? No, this is not possible.
Just so I’m 100% clear because I don’t want to brick my new watch, the firmware in the OP is for the LEM14 correct? From stock I flash v1.0 first and then v1.1 correct?
Just a slight but confused by the title stating LEM12
This is the right link:
-International Firmware [Beta4] (LEM12Pro, LEM14, LEM15, Prime2)
Note that this link is for the beta version, not the stable version.
