We will not be adding back any of these custom shortcuts because the reason we have better battery life is because we removed all these tricks etc…
Please take a moment to watch the video and look through all the available settings.
We are not going back to that old method which goes against the way Android is designed to work.
I watched the video and over all i like especially the thing which mr ticks told that tap and use floating toucher excellent😆.
Idk why but i charge the watch from 100 and keep it with me (unpluged)but in the moring 10%battery is gone when i have nothing running in back ground.
Over all I give it a 9.49/10 keep up the great work.
Thank you
Thank you for your reply.
No.2 is my mistake, you are right. I forgot to give authority. WatchdroidPhone works completely. Thanks.
No.1, about status bar, I understand that in FAW firmware I can’t use status bar.
@6eats
After more testing I can confirm that the only issues with bluish tint are happening when light is very poor.
This expected.
It has no way to compensate for poor lighting.
It is not a $500 camera and we have already got the best quality we can get from a 13mp watch camera.
So that is the end of this one.
Is there a BT connection between your watch and your phone? Also, is wifi trying to access location? On my android 7 watch I just press and hold over the wifi shortcut (swipe up) with wifi shut off and make sure the help apps find location even when the wifi is off isn’t ticked.
Also, when the watch reaches 100% you can leave it charging for an edditional half hour or so, then use watch until it dies, then try to turn on the watch. If it won’t turn on anymore then charge it again fully, let it pass 100% and maybe an hour longer. Do this in total of three times, then android battery checker should be pretty calibrated
Thanks for the guide and I have already installed the new firmware update/upgrade. It’s clean and smooth however, my current issue is that It seems to have lost the function of copying and pasting any files(Music and clock skins) using my desktop directly to the android watch folders easily using my charging cable. What I see now is just an empty folder. Any fix to this?
@longks22, settings > connected devices > usb > file transfer (only has to be done once)
@anon5802783, maybe it could be this for ota: settings > security > security update
Flash back to the original firmware if you want to get an OTA.
It should never overheat.
Did you factory reset the watch after flashing?
Its not a shame that they are in square mode.
They are in square mode for a very good reason.
If they were not - you would not have access to many of the settings…
I generally only use 1% per hour maximum over night…
Most of the time less.
Look like i should take pics outside now
Lol my rooms don’t have lightings that much.
About the camera i tried snapchat the camera wont rotate then filters wont open or support
I have not heard of this…
I must admit that we did not focus on the support of third party apps…
@none do you have any comments about this?
@6eats the other thing to remember is that this is a preview of the project. If it is not suitable for you it is very easy to return to the stock firmware :+1::+1:
This does not have to do any thing with the firmware it is great only thing is if i could use that app my photos could be much better then . Maybe try another app​:grin::grin::wink:
I have a lot of question i just forget just dont get annoyed :wink::hugs:
Another reboot, at about 15:14 - logcat2.txt - Google Drive
Does this happen with the default launcher as well?
I don’t know, I never use it. I’ll start using it now and see what happens.
You can easily switch between those 2 launchers without deleten UL. goto settings- apps and notifications- standard apps- start app. Choose the launcher here.
I can’t start “com.android.watchweather.Myservice” from Macrotool in FAW firmware. The service is locked. (I want to update automatically the weather. I know Universal Launcher has that feature, but UL has a few problems for me.) Can I avoid this problem?
No idea.
This is aimed at people using stock methods.
I think you are trying to achieve something that the stock launcher can’t do.
@Eric_Crochemore might have some advice?
This design is the same as the Prime 2 FAW version…
doing this will not in anyway change my sim card i.e i wont lose my contacts stored on my sim
