Well another factory reset did it for me, thanks. I’d done it when loading v.1.3 when on reboot the system came up with the error message I showed above. I reset using the workaround given by Rohit but obviously it wasn’t enough of a reset! Seems to be okay now. The minuses have gone from the step count and kilometre count and it’s showing proper step totals.
Thanks!
Edit: Oops … I put it on the charger while I went for a shower and when I came back the numbers have disappeared from the face and those that show in the step counter are negative again … Oh well …
on previous versions it was ok, so I don’t think it’s about the language, but ok I’ll go back to the 1.2 software because everything worked there in Polish
With FAW 1.3_b3 in LEM14 the charging symbol does not appear when charging from the computer USB port, but it does appear when charging from the power bank.
Because of the third party apps you have installed.
Give us a list of all the apps you have installed.
You do understand that beta means it is for testing right?
It is expected to be unstable.
It would be much easier for us to understand issues if you can get a bug report or logcat.
