isn’t my warranty get void for optimus2 after beta FAW installed?
No. You can flash back to the original firmware whenever you like.
I don’t think the crash protection is working … I installed the Lem14 version over the S10 I had installed and I just get a permanent warning that co.wiite.home.MyApp keeps stopping. I can’t get out of it or even factory reset (unless there’s a key combination?). I can get to the reboot screen and reboot but it doesn’t help. Any advice?
hello guys…updated my lem12pro to faw v1.3b…everything works fine for me…tqvm
Hmmm…some problems here with 1.3 on S10Pro. Namely, Universal Launcher refuses to run and crashes. Yes, I did a wipe. I’ll mention this in @Eric_Crochemore’s thread as well but this was fine before the recent changes so I suspect something going on the ROM side, not his. I’ve attached the full crash log for reference but this appears to have something to do with the display/GL stack due to the location of the crash being in the GLThread and the " GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false" before that.
08-27 13:42:03.686 18396 18396 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
08-27 13:42:03.687 527 1081 I SurfaceFlinger: [SF client] NEW(0x7f277820c0) for (18396:com.ricktop.ClockSkinCoco)
08-27 13:42:03.687 527 1081 I BufferQueue: [unnamed-527-396](this:0x7f276e8000,id:396,api:0,p:-1,c:-1) BufferQueue core=(527:/system/bin/surfaceflinger)
08-27 13:42:03.688 527 1081 I BufferQueueConsumer: [unnamed-527-396](this:0x7f276e8000,id:396,api:0,p:-1,c:527) connect(C): consumer=(527:/system/bin/surfaceflinger) controlledByApp=false
08-27 13:42:03.688 527 1081 I BufferQueueConsumer: [unnamed-527-396](this:0x7f276e8000,id:396,api:0,p:-1,c:527) setConsumerName: unnamed-527-396
08-27 13:42:03.688 527 1081 I BufferQueueConsumer: [SurfaceView - com.ricktop.ClockSkinCoco/com.ricktop.ClockSkinCoco.MainActivity#1](this:0x7f276e8000,id:396,api:0,p:-1,c:527) setConsumerName: SurfaceView - com.ricktop.ClockSkinCoco/com.ricktop.ClockSkinCoco.MainActivity#1
08-27 13:42:03.688 527 1081 I BufferQueueConsumer: [SurfaceView - com.ricktop.ClockSkinCoco/com.ricktop.ClockSkinCoco.MainActivity#1](this:0x7f276e8000,id:396,api:0,p:-1,c:527) setDefaultBufferSize: width=400 height=400
08-27 13:42:03.691 18396 18396 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
08-27 13:42:03.702 18396 18447 D Surface : Surface::connect(this=0xbeda1800,api=1)
08-27 13:42:03.702 527 1081 I BufferQueueProducer: [SurfaceView - com.ricktop.ClockSkinCoco/com.ricktop.ClockSkinCoco.MainActivity#1](this:0x7f276e8000,id:396,api:1,p:18396,c:527) connect(P): api=1 producer=(18396:com.ricktop.ClockSkinCoco) producerControlledByApp=false
08-27 13:42:03.722 18396 18447 F libc : Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x20 in tid 18447 (GLThread 217), pid 18396 (p.ClockSkinCoco)
08-27 13:42:03.790 18452 18452 I crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
08-27 13:42:03.791 658 658 I /system/bin/tombstoned: received crash request for pid 18447
08-27 13:42:03.793 18452 18452 I crash_dump32: performing dump of process 18396 (target tid = 18447)
08-27 13:42:03.815 18452 18452 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
08-27 13:42:03.815 18452 18452 F DEBUG : Build fingerprint: 'Lemfo/full_LW_C15_TFT_LFLT/LW_C15_TFT_LFLT:10/QP1A.190711.020/mp1V91961:user/dev-keys'
08-27 13:42:03.815 18452 18452 F DEBUG : Revision: '0'
08-27 13:42:03.815 18452 18452 F DEBUG : ABI: 'arm'
08-27 13:42:03.816 18452 18452 F DEBUG : Timestamp: 2021-08-27 13:42:03+0000
08-27 13:42:03.816 18452 18452 F DEBUG : pid: 18396, tid: 18447, name: GLThread 217 >>> com.ricktop.ClockSkinCoco <<<
08-27 13:42:03.816 18452 18452 F DEBUG : uid: 10100
08-27 13:42:03.816 18452 18452 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x20
08-27 13:42:03.816 18452 18452 F DEBUG : Cause: null pointer dereference
08-27 13:42:03.816 18452 18452 F DEBUG : r0 00000000 r1 00000000 r2 00000000 r3 00000003
08-27 13:42:03.816 18452 18452 F DEBUG : r4 c1b6dd58 r5 00000003 r6 bee85600 r7 bc2753b8
08-27 13:42:03.816 18452 18452 F DEBUG : r8 00000000 r9 bee85600 r10 bc275838 r11 bc2757bc
08-27 13:42:03.816 18452 18452 F DEBUG : ip c1b79e90 sp bc275390 lr c11a9141 pc c11a21e4
Again, this issue did not happen on 1.2. I also renamed my clockskin folder just in case there was a problem with one of the skins in there, but that did not help.
can i run my sim also on beta version
Of course, why not?
Yep, that’s what I’m getting when installing over v.1.2. The only files in my Crash Log on the watch are dated 8.4.2021. Not sure if that’s 8th April, American style, or 4th August, UK style. Whichever, they’re not today!
fixed, just erase all data by tapping app info and then search for reset from right top corner,
you were flashing over stock 1.2
Blockquote
The fix is to use adb shell, then run “am start -a android.settings.SETTINGS” to bring up the settings menu. You can then do a reset.
Thanks - I followed Rohit’s recommendation below and it worked … but I’ve just noticed the Weather app isn’t in the app tray any more. Do we know if it will reappear?
Yep, his is a bit more eloquent
yes its working do the factory reset again
the beta rom ultimate fast
The weather is part of the launcher now, see the changelog:
- Remade the weather application which is now part of the launcher, this also includes several fixes and quality of life improvements.
As I said before @Rohit_Bhandari read the thread
