Yesterday I could safely connect and download photos and videos on my computer.
Today, without any reason, an error message comes out. Unrecognized usb.
i have win 7 64bit.
I had exactly the same problem and I can’t offer a solution (yet), I’m sorry. But…
I’m now using an app called SHAREIt and I’m quite happy with it as a workaround. It transfers files using Wifi.
Install the app on your watch and the program on the PC, connect the two and you can transfer 1 or or multiple files or folders from the PC to the watch and vice versa over Wifi.
You can get the app here: play.google.com/store/apps/details?id=com.lenovo.anyshare.gps
You can get the Windows/Mac software here: www.ushareit.com/
Also avaialble:
iOS: itunes.apple.com/app/id725215120?mt=8
WinPhone: www.microsoft.com/en-us/store/p/shareit/9wzdncrdsz0p
I hope it helps.
Apr 24, 2017 22:21:12 GMT 1 galaxy76 said:
Yesterday I could safely connect and download photos and videos on my computer. Today, without any reason, an error message comes out. Unrecognized usb. i have win 7 64bit.
check in device manager if it detect the watch as an unkown device , btw are the drivers installed?
thanks for reply.
@ jcsmits
thanks, but i would like connected at pc
i followed this guide
but i have windows 7 and it is different. I do not have the voice “android phone”. i have only folder windows/inf, but the procedure fails.
anyware i have detect the watch as an “unknow device”.
and btw driver not installed.
But btw, are bluetooth driver? i would like connect with usb cable.
sorry for my english…
Apr 25, 2017 12:10:52 GMT 1 jcsmits said:
I had exactly the same problem and I can't offer a solution (yet), I'm sorry. But...I’m now using an app called SHAREIt and I’m quite happy with it as a workaround. It transfers files using Wifi.
Install the app on your watch and the program on the PC, connect the two and you can transfer 1 or or multiple files or folders from the PC to the watch and vice versa over Wifi.You can get the app here: play.google.com/store/apps/details?id=com.lenovo.anyshare.gps
You can get the Windows/Mac software here: www.ushareit.com/Also avaialble:
WinPhone: www.microsoft.com/en-us/store/p/shareit/9wzdncrdsz0pI hope it helps.
I've tried this method. For me it did not work. Do you want to try it out? www.tomshardware.co.uk/forum/242140-44-device-refuses-installed-please
the problem is I can not even see the voice “Android Phone” in windows 10.
my smartwatch do not find in “other device”, but in “Controller usb”!!
Apr 26, 2017 11:23:02 GMT 1 galaxy76 said:
the problem is I can not even see the voice "Android Phone" in windows 10. my smartwatch do not find in "other device", but in "Controller usb"!!
the guide that i did for the win10 is almost the same as the win7, and no you are not suppose to see your watch as Les1 but as a device on device manager.
Thanks, but I did not understand
if you did'nt insatll drivers or usb mtp then you wo'nt see your watch as LES1 but as an unknown device in "devices manager". 1. install drivers. 2. install usb mtp.
if you did’nt insatll drivers or usb mtp then you wo’nt see your watch as LES1 but as an unknown device in “devices manager”.
- install drivers.
- install usb mtp.
thank’s,
where find correct drivers and usb mtp for windows 7 64bit? please It’s three days that download waste that does not work on windows 7 64bit and windows 10.
Apr 27, 2017 14:20:56 GMT 1 galaxy76 said:Apr 27, 2017 9:54:13 GMT 1 soniasophie9697 said:
thank’s,
/thread/227/install-vcom-drivers-smartwatches-win10 (also for win7\win8)
Thanks, i try all, but not work in windows 7 64bit. any other ideas?
let me build a guide just for win7 and upload it i will do that on the weekend (saturday).
Thank’s!!!
IMPORTATNT: I only have the original dockstation provided with the Lemfo Les1! I do not have a 4-pin usb cable.
Apr 28, 2017 18:40:31 GMT 1 galaxy76 said:Apr 28, 2017 7:26:22 GMT 1 soniasophie9697 said:
it's ok, if that what you got in the package when you bought the watch you do'nt also get the other charger cable just a usb cable which connect to the dock. wait for my guide and see if it works if not then you might have a problem with the dock charger or the cable.
exact
Ok thanks for your answer I will wait
Are there novelties? Have you been able to connect the Lemfo Les1 to Windows 7 64bit?
sorry, did'nt have much time to do it, no, i do'nt have the Les1 watch but the guide should work with it as long the problem is SW and not the charger or the cable.
I have the same issue and so do most people. The dock is the problem.
You need to get a KW88 cable or I3/14 cable - they work perfectly
The standard dock is faulty for most people.
