If anyone still has the kw99 1/16GB variant watch can you please provide me with the firmware if you can I need the firmware to fix my watch
Look here:
-KW88 KW98 and KW99 Firmware thread
Sadly the folder on mega is no longer available
Oh, that’s a pitty. I don’t have this FW.
And when I asked kingwear about it they said we don’t have it
Maybe @pablo11 can help, I’m not sure.
I hope he does
Recently I was also desperately searching for the firmware for the Lemfo LF16 and I couldn’t find it anywhere I searched.
In the end Pablo11 helped me out of trouble and also guided me in installing with the right Flashtool! used in those days 2016
If he can’t do it here then no one can… Good luck!
I have already replied to a message sent to me.
Anyway, I need to know the original firmware version details.
Go to Settings, about watch, and see the version details.
@Ahmed_Hesham
Actually, I am guessing this is the Android 7 version if it is 1gb + 16gb, right ?
This is the only version I can get from the Chinese servers for the KW99 Pro 1+16GB Android 7 model:
KW99Pro_V1.3_B_20180716_16+1
My advice is to flash with SP Tool and use “download only” flash mode.
Just in case the screen is wrong etc… Having said that - there is no other version apart from KW88 Pro.
This is why I wanted to know which version you have on the watch at the moment.
The other thing I am interested in is - what are you flashing the firmware for?
Do you have a particular problem?
Yeah it’s the 1+16 GB version but and I can’t find the firmware anywhere to download it even using the firmware model you gave I can’t find it
And my problem is I can’t turn on the watch when ever I try to power it on no sound or video just the watch goes hot
Ok thanks,
In your message you said it was Android 5.1… Right?
Do you know why it does not power on?
When you connect USB to the pc… Does it charge?
Yeah it’s android 5.1 non upgradable “I guess”
It doesn’t power on because I tried to install asteroid OS and something went wrong
I believe it does charge the pc recognize it but it doesn’t show the charging screen on the watch
Ok thanks.
That should be enough for me to find an older version.
Are you sure it is not the 2gb +16gb version?
Like the AllCall W1…?
Great, thanks.
That helps
No thank you man for being heređź’™
