KW88 KW98 and KW99 Firmware thread
This link is for KW FW (88, 98, 99 )    goo.gl/KV3jL7
Latest Official versions
 - KW88_CS1_B_GSM_PHT_20171111.rar
 - KW98_V1.3_B_20171111.zip
 - KW99_CS1_B_20171111.zip
Please use version 5.1712 of SP Flash Tools
KW88 24/05/2017
NEW - KW88 FW RELEASE!!
Added today in the support forum KW88_CS1_B_GSM_PHT_20170518(SDK)
This includes the same face engine updates as the LES1, Thor and I4/I3 releases. It also contains the latest BT app.
KW88 28/03/2017
New kernel
DPI Switch in display settings
Minor bug fixes.
USE FIRMWARE UPGRADE OPTION IN SP TOOLS !!
KW88 07/07/16
Changes- Original firmware
Compatible with other watches- untested
Bug list- No 850mhz 3G
Notes- none
KW88 30/07/16
Changes- Added 850mhz 3G
Bug List- unknown
Notes- Do Not Flash Pre-Loader
KW88 21/09/16
Changes- Fix for random reboot
Bug List- unknown
KW88 20161215
Don’t forget - don’t select the pre-loader when flashing this update or you will:
a) possibly lose your IMEI and MAC address
b) won’t be able to downgrade if a problem occurs
