WP ^^ Was aware of api from the launcher to get extras outside the Watchnew apk ^^ Nice you find the trick to get it done… Are you a dev from china watchmakers ?
Thank you all, but I’m neither a genius, neither Chinese, I’m just a developer.
As you know the software on KW88 sucks! So, there are a lot of limitations, like: it’s only possible to put resources in the apk, so don’t get too excited! Most of the beautiful watchface images posted here can’t be done that way, because of the limitetions of Watchnew.apk The apk I have linked to this post has a problem too, can you find it?
Please be patient, in few hours I will post some description how to do it.
Reading your instructions, it’s a commendable efford you did here.
The function of the clock is explained in detail, but also a conclusion is made.
I believe it’s possible to create some clocks with this, but the restrictions are stiff.
But as all the other routes taken, they all have their pro’s and cons.
Thank you very much for sharing this option with us.
