Please leave a reply to this thread or join the telegram support group with the following information about your watch and we will respond if it is possible.
CPU: (Example mt6580)
Android Version: (Example Android 5.1)
What form factor is your watch (Round, Square, Rectangular)
Do you have a link to its firmware if so please provide it
If your watch does not run android we cannot make twrp for it so it has to be a mt65xx, mt67xx, mt2601
Once we decide if its possible for that watch we will contact you via pm/telegram with a build for you to test out
Aug 7, 2018 4:52:15 GMT 1ktl20 said: TWRP request for I6
CPU: mt6580
Android Version: Android 5.1
What form factor is your watch: Round
Can you make TWRP for this watch?
If it doesn’t work then don’t worry, we will try to build one for your device. However, if it works, then we would like you to report back to add the I6 to the supported watches list.
Aug 5, 2018 5:46:06 GMT 1deadman96385 said: Please leave a reply to this thread or join the telegram support group with the following information about your watch and we will respond if it is possible.
i have a z10, basically a thor,les1 and di06 clone from everything i can tell. it has the same specs as di06, reading around it seems as though i should use the method/files for the les1. not new to this but really want to make sure i get everything right. any and all help would be greatly appreciated. i’ve also been unable to get the dl links to work…
MODEL: Alps Z10-A
CPU: MT6580M
Android: 5.1
round
So in this community they can supply the firmware,so how are you guys are going to call for the Lemfo LemX smartwatch, maybe big ass watch or milky way.
when we are going to have the TWRP recovery and Magisk manager boot patch.
i want to start playing with my watch.
thanks great job guys.
Sept 27, 2018 23:22:47 GMT 1leafar said: So in this community they can supply the firmware,so how are you guys are going to call for the Lemfo LemX smartwatch, maybe big ass watch or milky way.
I have read that one can use TWRP for the LEM5 on the LEM6, which I did, and it partially works. Touch isn’t working. I have one version that the display is flipped 180 degrees, no touch, and the other, the display is ok, and still no touch.
Althought I can flash stuff from adb, it would be nice to have it working, as I cannot use aroma based installers.
TWRP request for Zeblaze Thor 4 Plus
CPU: MT 6739M
Android Version: Android 7.1.1
