how to connect two lemfo Lemt 2.8, 7.1.1 And Ticwris 2.8, 7.1.1! I can do ONLY ONE. YOUR HELP APPRECIATE.
I do not understand the question. can you describe in more detail what you want to do?
If you are wanting to connect two watches both turned on at the same time to a single phone via watchdroid or wiiwatch II app you cannot do this . But why would you ??
Thanks for the quick response. It’s because I have both and want to pair them with Wiiwatch 2 at the same time just like Wear OS. Thanks mate.
By the way, do you know if there is Ristwatch image to flash the Lemfo T because it has bigger fonts. Thanks.
Dr. Sam
Sorry but i have no idea what you mean ?
Dr Andy. I have Lemfo LMT 2.8, Android 7.1.1 with firmware 2019 and the fonts are soooo smale.
I bought TicWrist 2.8, Android 7.1.1 2020 firmware and the fonts are largere. So, I heard that if I can find the MAX 2020 firmware, I can flash it on the LEMFO and will solve the problem. So I need help with flashing this firmware. Thanks.
Dr. Sam
you’ll find the firmware for both lem t and ticwris max in this thread: LEM T Reviews and FAQs
try this
