Please tell me which is the correct process to change the volume when I tap at the center of watch.
I am trying this but it must be wrong (I can’t find the correct process name)
<drawable>
<arraytype>100</arraytype>
<centerX>0</centerX>
<centerY>0</centerY>
<!-- <range>30</range> -->
<cls>com.android.systemui.settings.VolumeDialog</cls>
<pkg>com.android.systemui</pkg>
</drawable>
I take it like the BrightnessDialog … but it must be wrong
Is this any good to you ?
I prefer not to install an app … I’d like to know the correct process in order to use it when I tap on the center of watchface
My smartwatch is the Kospet Prime SE
@meghgoswami835 I wrote that post not as a solution, but as a rough workaround. It’s not 100% what the OP wants, but close.
Yes, it doesn’t open the volume dialog, but it’s close (still there’s the volume adjustment sounds when you change the volume)
I have tried lots of these with bad results . Basically if you do not get the two complete lines from package viewer on watch its tough . Although i’m sure its not impossible
com.android.settings.SoundSettings
(android7.1)
