Help for newbies
I presume WFD stands for watch face designer but how do I get this software…as you can tell ive only just joined the site …thanks
You’ll find it here:
@philbybetts I also want to add that you will also need Java Runtime environment to run the file. Just Google it and download the version for your OS. It is currently supported by Windows XP or above, Mac OSX, and most distros of Linux. Just install it on any computer or windows tablet that you want to run WFD on and you should be fine. As @Marco_Ferreira is working on a newer version of the software, I recommend downloading the most current, up-to-date version that your system will support, for full compatibility. WFD 0.14.1 is the most current version, but Marco is working on 0.14.2.
