Thanks @George_Zervas
@Junaid_Siddiqui do we need root or no? Shake device did nit work. Can u pad help?
I hv instslled kingroot… then macrodroid and secure settings from play store. I do not know whether kingroot helped me to get shake feature…
I wil chk my x5 then reply u
Guys a tutorial for this without a root?
@Akhilesh_jj
Add new macro
Select shake trigger
Then Screen on/off Action
Then Need not Any Condtraint.
Save it Give any name.
Now Step second.
On MacroDroid Home Screen…
Click Settings.
Go to trigger options
Then Senstivity to level : 5
Shake Detection rate :Normal
Tick mark : while screen off.
Then you will be able to use this macro to turn screen on…
All the best.
I dont think root is required… @Akhilesh_jj
First try on mobile phone then on watch…
@Junaid_Siddiqui thanks a lot…
I wish u get success @Akhilesh_jj
Guys which keyboard do you use?
Stock keyboard…
@Junaid_Siddiqui Thanks, there is a way to install an older firmware
I hv not tried… i m on stock firmware on my x5
This method for wake up the device will drain a lot of battery? There is a way to set it better? Because i need to shake a lot my wrist before it turn up, i want the gestire down-up
@Mirko_Genovese are you root?
@George_Zervas No, i have a kw88 no root, there is a way to root it?
@Pablo_Eleven_Pablo11 i also found secret codes that archived with simple apk from playstoee
Mtk use secrets code to lock or unlock fetures
Oem mode
Engineer mode plus some hardware test
I dont think that can help but is good information for those with problems with hardsware
@George_Zervas MTK Engineering mode shortcut apk ?
Yes - it is a handy tool indeed.
If you have any codes that you think may be useful please post them.
But they have to be used with caution. …
