Nov 29, 2017 11:08:51 GMT 1elcolombia17 said: Or maybe the I4 air firmware will work, yesterday I used system.img from zeblaze and it “works” but many option in menu no appear.
if i’m not mistaken you can but without the preloader marked, better to wait for the developers comfirmation:)
Some news.
I had been talking with seller and he/she sent me a firmware labeled AQR-LAUNCH-I4PRO-1602-FITNESS-HEHUI-NHT-V01-20171121, I flashed it and problem continues, but now the PC recognize the smartwatch like i4pro.
So I did some test and finally I can get fully working screen, I used the latest lk.bin and boot.img from microwear h2 smartwatch found here m.microweartech.com/en/MicrowearFirmware.html, the problem now is that screen is flipped 180°. I tried modify the build.prop with ro.sf.hwrotation=180 and screen show right but touchscreen works like a beginning. So I think the main problem is on boot.img or in lk.bin or on both, but I don’t know how to modify this.So if any knows how to rotate imagen on boot.img configuration…
PD: I was able to flash firmware from h2,kw88, kw98, les1 and zeblaze smartwatch, only choose to flash system.img, cache.img and userdata.img,
but I don’t like any
Maybe with this test we can get root access and TWRP on this model.
I can confirm that this is the same firmware that came in my I4 Air. I have not done an update for two reasons. One my watch works perfect and two Mr. Ticks found an abnormality in an I4 Air he was demonstrating. On all the watchfaces displayed the screen was rotated slightly left, enough to notice. His watch was running a later firmware than mine. Since I was unable to determine what firmware I would get if I did an OTA update I just have not updated the watch.
Maybe you can help me with boot.img
Extract it with advance commands please
Dec 12, 2017 20:37:13 GMT 1capt jon said: I can confirm that this is the same firmware that came in my I4 Air. I have not done an update for two reasons. One my watch works perfect and two Mr. Ticks found an abnormality in an I4 Air he was demonstrating. On all the watchfaces displayed the screen was rotated slightly left, enough to notice. His watch was running a later firmware than mine. Since I was unable to determine what firmware I would get if I did an OTA update I just have not updated the watch.
Can't extract the firmware because don't have proper connectivity with pc over usb. With all needed drivers (vcom and all...) don't work. Mtk droid tools can't see my watch. It is a watch or firmware problem. 😕
My personal watch faces was transferred via wifi with "wifi file transfer" app.
The Bluetooth also don't work fine. No connection! Only with wiiwatch original app and is not perfect
Dec 12, 2017 11:43:12 GMT 1elcolombia17 said: Some news.
Do you still have a link to download this I4 *pro* firmware ?
Thanks !
Thanks !
