Any new firmware that’s coming out for the I4?
I have the 8GB version.
Still not satisfied with the bluetooth connection and gps accuracy.
Jul 27, 2017 19:09:04 GMT 1 test222222 said:
Any new firmware that's coming out for the I4? I have the 8GB version. Still not satisfied with the bluetooth connection and gps accuracy.
will check...reset and flash the watch mostly help to fix the bugs.
will check…reset and flash the watch mostly help to fix the bugs.
Any news?
Has anybody a newer firmware than this from july 2017 for flashing the I4Pro 2GB 16GB?
any new updates of FW will be in this section: /board/12/factory-firmware-downloads
Hi, I have a big problem, I flashed the firmware for my i4pro 2GB/16GB and now the screen no works, the smartwatch turn on, connect to pc but no imagen, I think the problem is the ROM I use says I4 2gb instead i4pro 2gb. Can someone help me
PD: sorry my English
Can you tell me which firmware version do you have? And if is possible to make a backup?
Nov 28, 2017 13:06:50 GMT 1 elcolombia17 said:Nov 9, 2017 10:55:24 GMT 1 soniasophie9697 said:
that is a problem, did you mark the preloader? download the right firmware for your watch and flash it and hopefully it will be fixed.
Yes I did I think, the problem is find the right firmware.
Mine says AQR_LAUNCH_I4PRO_1602_FITNESS… But I can find it anywhere.
Some news
I read about firmware and learn that lk.bin has the info to manage the screen etc so I opened the smart watch and can read C1S 80m e1616 and reading on board i was able to read kw88 so I tried the kw88’s lk.bin and now I can operate de smartwatch but screen is flipped 180° and when turn of by time I can not turn on because I get black screen with frame on top.
So im close to get it working again.
Only need a little help (lk.bin from a working I4 pro)
Nov 28, 2017 17:34:05 GMT 1 elcolombia17 said:
Some newsI read about firmware and learn that lk.bin has the info to manage the screen etc so I opened the smart watch and can read C1S 80m e1616 and reading on board i was able to read kw88 so I tried the kw88’s lk.bin and now I can operate de smartwatch but screen is flipped 180° and when turn of by time I can not turn on because I get black screen with frame on top.
i’m still checking about the firmware for your watch you need to flash the right stock firmware to make the watch useable.
Thank you so much
I remember that in about phone it says AQR-LAUNCH-I4PRO-1602-FITNESS…and more merory…
Nov 28, 2017 19:23:45 GMT 1 elcolombia17 said:Nov 28, 2017 18:31:38 GMT 1 soniasophie9697 said:
Thank you so muchI remember that in about phone it says AQR-LAUNCH-I4PRO-1602-FITNESS…and more merory…
do you remember if your watch is the 512mb\8gb or the 1gb\16gb ?
Mi watch is 2gb ram, 16gb ROM and for more information, circuit board has connector for camera
Nov 29, 2017 8:12:27 GMT 1 elcolombia17 said:Nov 29, 2017 7:17:45 GMT 1 soniasophie9697 said:
does it have camera?
we can't be sure about the watch and it's firmware because you flashed it, can you provide us with a link to the watch where you bought it from?
we can’t be sure about the watch and it’s firmware because you flashed it, can you provide us with a link to the watch where you bought it from?
This watch no has camera but board has a connection por it.
And the original firmware says something like this AQR-LAUNCH-I4PRO-1602-FITNESS
I4 Pro Reloj Inteligente 2 GB
16 GB de Memoria SIM Soporte 3G WIFI GPS Recordatorio de Llamada y Marcar Monitor de Ritmo Cardíaco Reloj Smartwatch
s.aliexpress.com/jaYfeeuQ
(from AliExpress Android)
Nov 29, 2017 8:46:45 GMT 1 elcolombia17 said:
ok, there are 2 i4 pro with different screens, we will try to get as soon as possible the other firmware and you'll have to flash it to make the watch work again.
ok, there are 2 i4 pro with different screens, we will try to get as soon as possible the other firmware and you’ll have to flash it to make the watch work again.
Or maybe the I4 air firmware will work, yesterday I used system.img from zeblaze and it “works” but many option in menu no appear.
Nov 29, 2017 11:08:51 GMT 1 elcolombia17 said:Nov 29, 2017 9:01:04 GMT 1 soniasophie9697 said:
if i’m not mistaken you can but without the preloader marked, better to wait for the developers comfirmation:)
