I flashed the latest firmware onto my X5 Air today (goo.gl/A1i3yB).
I’ve had problems with the GPS since I got the watch and thought that the firmware update might fix it, but it didn’t…
I installed the GPS Test app and tried to get a fix, but it couldn’t fix to any sat.
Then I installed the MTK Engineering app and did a GPS Test, and after 10-20 seconds I had a fix to seven or eight sats.
Went back into the GPS Test app and I still couldn’t get a fix.
Same thing happens with Waze and Google Maps…
This is kind a deal breaker for me, since I got the watch thinking it could replace my phone on the golf course (using Swing by Swing).
But since Swing by Swing can’t get a GPS-fix it’s useless.
Same problem here. No GPS fix. Have the same problem on X5 plus and now on X5 Air. ( I did all the recommended steps… outside, connected to internet but still no GPS fix).
Hi Sonia . Do you have any idea if Finow are going to address this problem ? A friend of mine also just bought one and same GPS issues as me and others
Aug 29, 2017 20:26:32 GMT 1Tim And Pierce Collins said: Hi Sonia . Do you have any idea if Finow are going to address this problem ? A friend of mine also just bought one and same GPS issues as me and others
I’ve just checked on ma X5 Air, and i had a GPS fix (using GPS Test App). Just had to have WIFI ON in order to get the AGPS data.
I’m using the last FW of beginning august.
Hi eric . Which app are u using ? I will also give wifi a try when i know which app you are using , I am waiting for OTA update ( any idea if OTA ) . Havent got a pc so no flashing
No root
Aug 30, 2017 19:39:39 GMT 1Tim And Pierce Collins said: Hi eric . Which app are u using ? I will also give wifi a try when i know which app you are using , I am waiting for OTA update ( any idea if OTA ) . Havent got a pc so no flashing
No root
Aug 30, 2017 12:18:44 GMT 1ricktop said: I've just checked on ma X5 Air, and i had a GPS fix (using GPS Test App). Just had to have WIFI ON in order to get the AGPS data.
I'm using the last FW of beginning august.
Interesting. My X5 Air says firmware is up to date but firmare version is from 170711
