Hi, does anyone know an app that allows you to turn on the Kospet prime screen with a double tap and the possible battery consumption? I’m not looking for Always on Display apps
Not sure it can be found separately from AOD
This is not possible . Sorry
Well, it might be possible, but that will require you to flash a custom kernel.
Can’t tell much about the general battery consumption, only that the touch controller should consume less than 1mA in idle mode.
Good luck with this
. This option has just become available on the " not full android watch SG2 "
