I purchased the Domino DM368 which is essentially the same thing as the Lemfo lf16. I’m not sure if this is the correct place to put this, but thought I’d share some quick info…
Ordered the watch from GearBest the Friday before Christmas and it came Tuesday. Was really surprised it came so quick from China.
I have loved the watch so far. The battery life has been pretty good, good enough for me. I’m fairly light use, but do use it for cel, texting, and have gps on with a sim card in.
The one issue that just popped up today (Friday), so only been used since Tuesday, is that I noticed I no longer receive notifications via the vibration. I ended up downloading an app which will vibrate a phone and it will not vibrate using that so I have contacted GearBest. I got the usual reply it appears asking for a video of the problem.
Has anybody had the vibration quit on these things?
On a separate note, does anybody have firmware for the DM368 or I’m assuming the Lemfo lf16 would work also? Any idea?
We (the moderators/firmware archivists) don’t have either on hand so no firmware at this time.
As far as the vibrate. Can you get the watch to vibrate at all? It should vibrate when you set it to a vibrate only mode or use an app on the watch that vibrates.
Yes, I had checked the sound settings, thanks for idea.
What should the following do…
Settings > power saving > super power at the top > then enable or disable ?
The strange thing is it was enabled, but I was still using the watch like normal only no vibrate. Battery usage was amazing. I turned it off and vibrate came back.
When I turn it back on now, it goes into that mode when battery gets low. I can’t turn it on and use watch like normal. Something must have gone wrong before allowing it to be on and still use watch? Ideas?
reset the watch, i do’nt have super power in power saving, can you use bt and wifi and 3g with it?
Super Power is just the text at the top above the graph. You don’t have that text? If not, must be something unique to the lf16/Dm368?
Yep, all the functions are working right now. I think the battery was a little better when it was in the weird state, but it’s still working pretty good.
Dec 31, 2016 19:50:07 GMT 1happycamper said: Super Power is just the text at the top above the graph. You don't have that text? If not, must be something unique to the lf16/Dm368?
thanks for the info:)
edit: nope, does’nt work for me it turns off when i open wifi or bt
Yes, but if you turn on “hand bright screen” the battery does not last all day.
With normal use, one and a half days or more.
Without wifi connection, without gps, without bluetooth, it can reach more than 2 days.
Sorry, I'm not sure I understand what you are asking. I think you are asking will it answer a call without a sim. If so, here is my explanation...
I use hangouts and a google voice number. So as long as I have some connection to the internet, I can answer calls, send texts. This means if I’m on wifi, I can answer a call etc… If not on wifi, I can only answer a call by having a sim card in. Hopefully that makes sense.
What is ios? I’ll have to check if I see that running. Thanks!
i always find that something which is connected to ios and bt always runs and it has a big impact on bettary life i’m sure that with root i will be able to sidable or even delete this files, i do’nt use or ever use iphone so i do’nt need it on my watch.
