If I wear it in the right arm and twist to check the time it works perfect!!
But in the left arm ( opposite direction) not working.
It seems that the sensor settings read in opposite way. I tried and it works on that way.
Is there is a way to recompile the kernel file to control the Sensor reading to redirect the sensor reading
Br
Emad
Here is the dmesg for the LEMT firmware 2.0. This firmware doesnt heat up as the ticwris, but there seem to be a lot of gliches in the ticwris firmware in general. Somethings are done right in the TicWris Max firmware and vice versa with the LEMT. dmesg
Hello all, I need some guidance on how to build my own LEM 12 OS. The base that ships with it has a lot of issues and bugs for my use, and I need to fix it. LEMFO is refusing to fix it⦠I was able to get the source code from OpenWatchProject/android_kernel_mediatek_mt6739 and OpenWatchProject/android_device_wiite_c7s but I was not able to make much more progress than that. Any help or advise will be much appreciated!
Personally, I suspect that not many developers are concerned with Android 7.1 devices anymore. I know that for Android 10 devices developing is running in the background. The open watch team is still working on 7.1 devices, but you already know this.
As a matter of fact. However, I have a large collection of fine wines in the catacombs under my house. However, annoyingly, thatās not what he was asking forā¦
