Summary:
- This is a reversed or re-created kernel source for the MT6739 Smartwatches, this is mostly intended to have a reference source that might be able to support future development.
Edit:
No longer maintained.
Summary:
Edit:
Maybe itās a silly question, but I have to ask⦠What is the potential of a custom rom? Forbidden functionalities like bluetooth calling?
Prime SE also ? @none
@Giorgos_Tsarouchas
Primarily a more recent Android version with all included fixes and security updates.
@SERZAO
It looks identical to the Prime except for ram/storage, you might try it.
But be sure to create a backup / get a copy of the prime se firmware.
OK sir, this looks promising
Great work! Will this work without overwriting the user area? If so I will start trying this immediately.
It should start the flashing process now, donāt interfere with the device until the process is done.
@none Thanks for your work and thanks for posting this in the right place
So far so good, no problems or differences that Iāve noticed. Is there something in particular we should try to stress test?
Iām actually wondering what benefits you will be getting from this kernel?
@none is there something in particular that people will notice if they flash this kernel?
Iām curious because we have had them before and tweaked governors and other things but no benefit was ever realisedā¦
Great stuff by the way and Iām very grateful, but what do you think?
Better battery life or something else?
@Bozley
Thanks, most important is that everything is working correctly (accelerometer, cameras, heart rate, sim, gps, charging/discharging, battery life).
@pablo11
As mentioned in the first post:
This is mostly intended as āreferenceā source that can refered to when migrating to a higher kernel version.
Ah ok,
I certainly didnāt want to give the wrong impression because I am very grateful that you have taken an interest.
Not only in working on these sources with the Openwatch team - but also posting your work here as well.
We have worked with the Openwatch guys for quite a while now.
Iscle is a moderator here as well, for example.
When he has the time
Anyway, welcome aboard
Thanks, i was looking for a small android / embedded device to tinker with and those full android smartwatches were ideal.
Yes, Iscle and Deadman did a lot of awesome work for the OpenWatchProject, make it possible in the first place and can be credited as well.
While listening to and navigating the YouTube Music app my Prime crashed. I had to hold the power button for about 30 seconds to boot. I got it to happen 2 more times so itās a repeatable bug. After reverting to the original kernel this problem hasnāt happened again.
Can you provide me a log when this happens?
Here is small archive that includes adb.exe and a script āLogfile.cmdā that will pull the last kernel log from the device (usb-debugging needs to be enabled).
Here you go
Thanks for the log, i made a new build that hopefully fix the music crash issue: PRIME #2
I also made some slight changes to the heart rate sensor, please check if itās working correctly, thanks.
The HRM is not working - the testing app says ātest failedā. Iām pretty sure it was working with your first kernel. I also had a crash. Same situation but it took longer to crash than before. Hereās the log.
Thanks again for the logfile, it is unfortunately still the same problem.
Seems to be caused by the āfpsgoā driver and a missing proprietary kernel module (which isnāt included).
Itās intended to boost gaming performance, but i donāt think this has a lot of use for our smartwatches, so i turned it off.
Anyway, here is a new build that should fix this issue: PRIME_#3
The crashing bug does seem to be fixed, and HR is working again. I tested every feature* (though not always extensively) and everything seems to be working correctly.
*Except phone features; I donāt have a SIM card in my Prime.
