CD55Max W527 smartwatch
Interesting battery idea
  1. Do you have a URL to order this?
  2. True Android version?
  3. True memory size
  4. Can you switch it to developer mode.
That’s cool battery replacement concept
No . Unavailable at the moment
Super idea
https://www.alibaba.com/x/1lATUcp?ck=pdp
Early model has usb connectivity issue. Buy at own risk. I have just ordered one
android 9 upgradeable to 14
4/32 4/64 two real options
can enable usb debug
I’ll see what its like when arrives. Shipped tomorrow
what are the USB connectivity issues your aware of, and, how much are they charging for a single unit ?
£ 85 single unit shipped DHL fast
Unsure on usb connection problems as could have been a test piece
Thx, any pointers on how to enable USB debug and to upgrade to Android 14? I think in another topic I saw you have a utility to enable the USB debug (so I can side load apps)?
thanks for that, it’s a tempter, but i remember having one of this design once before, that lump of metal besides the crown gets in the way of the camera !
it is not needed to use usb debug to flash android 14, you can just watch my video about flashing w527
Yeah all Ultra style currently in production have this issue. You want to check the S10 Style
Android 14 (technically A13 or maybe A12 could be enough but A14 would be great)would be needed because I want to serve AI models with MediaPipe. To deploy an APK on the watch I’d need developer mode enabled (?). Can you or anyone you know upgrade the memory in such a watch for a commission?
since you just need proof of concept yes a14 can boot just have ultra high power consumption
This watch will be with me monday
Recieved and testing. As expected no connectivity with PC at all. Just charging. No hardware issues to report. Comes with two batterys. W527 chip. CN firmware stable with no issues. Using @AILIFE Rtosify with no problems. There is no way this watch can get wet. Battery seal is present but i dont imagine it doing much. Gps very powerfull like S100 and no wifi issues unlike the CD12 max. Works with UK sim. See images / Red battery seal.
Did you try both battery for USB and make sure connection is good, the problem is just the battery quality, also make sure USB is enabled (not adb, there’s matter control for USB)using engineer mode through developer helper
Only tried one battery so far. Developer helper doesnt allow usb in engineer
Is the USB connection problem because the extra layer the battery makes messes up things?
