CD55Max W527 smartwatch
Thanks to @AILIFE it now works
Interesting. It is very expensive though. You can get the 4/64gb version with chinese agent for around $100.
Very true. I paid a lot less
How did you connect the watch to the pc? I enabled debugging and used a 4pin charger, but it didn’t work.
it is not possible if you have the cd55max which is the topic here
because this watch have removeable battery usb is not possible without hardware modification
Had anyone succesfully disassembled this watch? My sim card got stuck inside…
From what I have found, there are no screws under the waterproofing band nor under the hinges.
