Please is anyone who knows? The Bluetooth connection between the watch and anything else, computer, phone, etc. is not stable. It connects and disconnects continuously, in second.
Is there a setting I don’t know about?
I had the same problem (Kospet prime) I just uninstall the wii watch 2 app (the default theatering app) and the problem was solved now the conection is very stable, rigth now I use watch droid.
I also use an app you can download in the playstore (Bluetooth Visibility Fix)
Thanks for the reply, unfortunately it didn’t work for me. Other thoughts?
Are you using this with watchdroid on phone ?
Hi, It all started with the Watchdroid app and then I tried a simple bluetooth connection with the computer and even with the phone for a file transfer and the bluetooth connects and disconnects immediately.
Have you tried a factory reset ? I’m sure it wont be hardware related
Yes. I did it right now, and without any installed application the same thing happens. It seems that I can only synchronize contacts from phone to watch.
Only the contacts and internet option appear in my BT settings
If I want to transfer a file, I can’t through BT because it connects and disconnects continuously. The same goes for WatchDroid if I want to connect it with the watch.But I also mention that with Bt audio headphones it works.
@Dr_Andy_Vishnu In the case of WatchDoid, maybe, using a SIM card with a dedicated number, is not working but it is not explained why I can not connect to the computer or phone. Anyway, thank you for your support.
Can i ask . Is watchdroid turned " off " under battery saver and data saver ? This avoids the app sleeping and should keep the two connected .
I am familiar with all procedures. It was. Now it’s erased and uninstalled
@Dr_Andy_Vishnu So, I’m not necessarily interested in the connection with watchdroid, but only the fact that I can’t connect for file transfer. although it can be done by other methods like USB direct wifi etc. Is there any new firmware other than the one that comes with the watch? Thank you for your patience.
Not yet but a update is coming . I am concerned your watch bluetooth was working and now it is not ? You should have no issues on the current firmware . A factory reset should have fixed this
How do you uninstall Wii Watch ?
When I tried, it looked like one of those factory installed apps, where you can only remove updates, but not the whole app ?
the tethering App for the prime2 is Wiiwear
You can delete every single app by using the software “minimal ADB and fastboot”
I am having this issue as well, won’t connect to Bluetooth on my smartphone. It connects and then disconnects. Uninstalled WiiWear app and same problem. Also has issues connecting to Wifi. I think that might be because my Wifi network is not broadcasting, as I am able to connect to another Wifi network that is visible. Still, it SHOULD work in any of these circumstances, and I would say it’s a firmware and/or hardware compatibility problem. It would be nice if they fixed it. I love the watch, but connectivity is a fundamental need with a smartwatch, and without that it’s usefulness is very limited.
If you’ve tried wiiwatch, you’ll need to do a factory reset for the Bluetooth to work normally again. I recommend using watchdroid instead. It works very well.
Ah ok so just found out the watch won’t connect to Bluetooth directly from the phone, as per the watch user manual. That was my mistake. I set it up with the WiiWatch app and it connected successfully to Bluetooth. I am going to try Watchdroid as you mentioned too. With the WiiWatch app I tried downloading a watchface using my phone, but seems like that is not working. I tap the down arrow on the watchface, it becomes a checkmark, but then goes back to a down arrow, and nothing happens. Any ideas?
The watchface server is down, if I remember right. But you can download thousands of faces here.
