Hello everyone! Is it possible to somehow install android wear faces on zeblaze thor 4 pro?
Yes, if you use Universal Launcher. It can also handle .watch-files.
You can also use my wallpaper…
Thanks anico! I tried to put the .watch file in the “clocksin” folder but it didn’t work … How come?
Eric What is your background?
Meanwhile, thank you! I installed “universal launcher” and put the .watch file in the “clocksin” folder but it didn’t work … How come?
Have you rebooted watch ? . They usually appear after this
That’s Clockskin, not clocksin.
Then try with my launcher, your watch is maybe not compatible with the wallpaper
Your launcher is “universal launcher” right? I’m using just that
Then it should work, look our YT channel tutorial
This skin works good. What’s the problem ?
Of course it works. But you first have to set your location in the launcher settings. On our YouTube cannel you can find a video on how this works.
