That is good. Thanks for the feedback
Have you tried to press both buttons to force a reboot?
Nope… i just press and hold power klik reboot…
And looping again
i have try with v 1.4 but still stuck in “error, reboot device”
Are you saying you installed firmware and this happened ? Did you peform using " local update " ?
We are talking about android 11, Doc.
Have you noticed that you have to press and hold the back button during the first part of the flash process?
Yess i press and hold back button until status “passed”…
After that i turn on device,
Display from device
Next i klik confim,
Next until notice “error, please reboot”
Almost done sir,
Many Thanksfull for mr @pablo11 for solution…
Best Regards,
Galih Jayendra From Indonesia…
No problem @Banyubeningprotol
By the way, if this account is also yours
We should merge the two @BanyuBeningPro
Meanwhile, I am talking to our friends about what caused the pixart fw down grade problem.
Yes sir… there’s my account ![]()
Sometimes ago, im forget to login… ![]()
Mybe chipset, not supported to downgrade sir… ![]()
I wish it was that simple.
But I have downgraded from other versions with no issues.
The chipset fully supports it and it is usually OK.
In reality, this means that there is an issue with the v1.6 pixart firmware.
That is an independent process and has nothing to do with flashing Android.
That’s why your watch was stuck at this point and unusable.
So it’s a serious problem ![]()
And Now My watch Normal, No Upside Down Camera sir…
Really?
That is extremely interesting and I can’t explain it?
Good news of course… ![]()
Have you factory reset your watch after flashing?
Sure… Camera normal not upside down at whatssapp call
Nope… Iam did’nt Factory Reset… amazing sir… ![]()
I am concerned that a factory reset will reveal the problem is still there.
Cached files could be fixing the problem but only if you don’t factory reset.
Would you be willing to test this please?
Unfortunately, it is only the latest stock which has firmware v1.6 that are using the new G-Sensor module (which needs firmware v1.6).
The reason why you can’t downgrade is because the factory has set a “no roll back” flag for the second (Pixart) chip.
I have confirmed this and if you have a watch that comes with v1.6 installed and has the new G-Sensor - then you cannot downgrade the firmware.
Yes sir, I Understood…
Thanks for confirmation to the team official…
Now… I’ll waiting next OTA… and hope can tap to wake like wear os… ![]()
Next… at app GAOFIT can choose application notofication… like as FitCloud Pro…
Actually I use too Zeblaze Vibe 7 Pro…
I understand, it is a pain resetting the watch ![]()
I Tryed to Reset Factory… The function everything normal…
But I found, in Round Square… The screen Blinked Thinly… that happen if i open play store, and more corectly White background… but its no problem… liltle trouble… ![]()
