Hi guys after I upgraded my Kopset Optimus Pro to firmware 3.0 now the long standby can’t sleep the display and normal use with 3G/4G connectivity drain within a day. Or is my watch battery degraded?
You can set whether you want aod or you want the screen to light up only when you raise your hand by clicking on the gear, long standby mode works fine for me on v3.0 and the display goes off
I usually use 3g but on 4g my watch doesn’t last more than a day as well
You right, i missed this part… Thank you.
