A8.1 developer options
On A8.1 you can install clockskins if you install universal launcher from this forum
However widgets disappear after reboot
I mean to install ClockSkin format dials in other launchers. for example, on the desktop of a smartphone in the form of widgets, maybe there is some way?
This is as much as i know
I installed the app but it doesn’t appear on the desktop, maybe there is a newer version?
I could also install a universal launcher, but it is so outdated that it is unpleasant to use it. Has no one yet made a more functional launcher for your android watch?
This is the latest version updated recently
And yes it is " universal launcher "
Last question, I’ve seen a watch app here somewhere that allows you to delete and add watch faces over wifi via a browser on your computer. Can you tell me what it’s called or give me a link? I found it, but I forgot where and what it was called.
the file is no more available but I’ve found on the playstore
 maybe it work
Just tried the file above and it works fine ?
The link of USB debugging to Google drive doesn’t work
Siamo spiacenti, il file che hai richiesto non esiste.
do you still have that APK for debugging please ? link is empty unfortunatelly.
This app need Android 11. H18 or H19 : doesnt work on your device
I’ve find a way who work to enable usb debugging on my H19 watch, the apk is ‘Smartwatch devoption apk’. You have to go in eng test mode in this app and have sim card inserted. Watch connected succesfully on computer via usb with this app. Thanks to XDA forum.
Can you provide a link
or
how is the battery quality on your h19 watch after many months of use?
Totally fine
and this developer helper apk enables the data transfer with pc using the included 4 pin cable?
one more question about h19
can i install custom watchfaces like the red radar watchface found here on faw with clockskincoco 3.7 apk ?
