1. you create on your pc a folder named Clockskin.
2. you copy ONLY folders which contain mostly png. files and not folders.
3. the folder that you created on your pc copy the Clockskin folder you copy that to your watch and you have new watchfaces.
***remember when you delete or remove a WF from this folder you need to be on stock face on the watch.
hi guys! Writing from Russia!
I bought two pieces watches. The problem is that they are VERY quickly discharged, not even enough for half a day!
The software is very bad! Barely managed to connect the phone with the watch.
SMS notifications come direct to the watch, but the calls will not appear! help Board.
if there is anyone that firmware, throw off please! Thank you all!
On Russian
Привет ребята! Пишу из России! Я приобрел двое часов. Проблема в том что они ОЧЕНЬ быстро разряжаются, не хватает даже на пол дня!
Программное обеспечение очень плохое! С трудом получилось соединить телефон с часами.
Смс уведомления приходят прям на часы, но звонки никак не отображаются!
помогите советом. если есть у кого то прошивка, скиньте пожалуйста!
Спасибо всем!
try first to reset the watch and if it does'nt help you should contact the seller who you bought from and ask him for the software he will provide it.
can you tell me plz what is your model? i might be able to help with software but only if the model fits look under phone info if your model is w626 if so i can help. is the watch also mtk6572? 2cores or 4cores?
try first to reset the watch and if it does’nt help you should contact the seller who you bought from and ask him for the software he will provide it.
Model is ZoiyTop JM01 (Microwear H1)
mtk6572 - 2cores, 512 mb/4 gb
I don’t know how to find w626 it or not.
post pictures of the system.
ok, we have different models i assumed because yours is 1.4 inch and mine is 1.3 inch, do as i did i got the stock rom from the seller who i bought the watch from and i see no reason why you can't get it.
ok, we have different models i assumed because yours is 1.4 inch and mine is 1.3 inch, do as i did i got the stock rom from the seller who i bought the watch from and i see no reason why you can’t get it.
If you’re looking for an Android watch phone with removable bands and good battery life, consider the Omate Rise. Hard to find, only 2000 pieces are made.
It has a 580mAh battery, is waterproof to 1ATM (that actually means not waterproof at all, splashproof I guess). Also the battery indicator is very accurate (no surprise like dropping from 60% to 0% in just minutes). Nice and unique feature: you can set the display always on and it doesn’t affact battery life too much!
Drawbacks: thick (17mm), not hearth rate monitor build in, little memory (512MB/4GB), view watch faces, large bezels and rather ugly design. But signal recepetion and battery life is good!
I tried both and I was able to solve it… kind of. Here my findings:
Elephone P9000 Android 6: No connection.
Zopo Speed 7 Plus, Android 6: No connection.
Elephone S7, Android 6: No connection.
Umidigi Z Pro, Android 6: No connection.
The watch can be seen in Bluetooth, can be paired and an connection attempt is made but it’s dropped after aprox 0,5 seconds.
But now it gets interesting:
Elephone P9000, S7, Umidigo Pro after upgrading to Android 7: Pairing ok, connection ok, sync ok and notifications OK.
I also discovered how to get the smartwatch sport data into the watch: The FunFit app has in the “main” section in the upper left corner a “sync button” which will sync the workout data. So Mr Smartwatchticks, this is also solved now.
Regards,
Rafael
EDIT on Battery life so far: I’m running the watch now for 3 hours, WIFI off, BT on, phone/3G off and the battery still displays 99%. Doesn’t look that bad. My Zeblaze Thor is meanwhile down to 86%.
Hi… This watch can use bluetooth connection to smart phone to receive call and msg (whatapp & wechat),right?
Can it able to show the content of the msg (whatapp & wechat). Pls advise.
no, it is a bull android watch, and there are the issues with google itself because they do'nt support these watches because their android Wear watches, so for the near future that is not going to happen unless an app developer will be able and also it will be limited something to do with security issues.
no, it is a bull android watch, and there are the issues with google itself because they do’nt support these watches because their android Wear watches, so for the near future that is not going to happen unless an app developer will be able and also it will be limited something to do with security issues.
Aug 2, 2017 20:24:13 GMT 1tt said: Plan to buy the H1... Anyone can give me some advise for the pro and con about H1?
Thanks in advance.
i do'nt have it but i use the Q7 and also have the S1 which both are mtk6572 and dual cores not 4 cores, and i get great battery life with always 3g on and wifi, BT and gps turned on for hours and get more than a day of usage. with m2d on i get almost a day usage between 15hr to 24hr. i barely use it for calls and sms just if really need to. this watch is also ip68 that is important thing, antennas are NOT in the straps that is a huge + because i had a x3+ which i loved but the strap disconnected and there was no way to fix it a perfect working watch can't be used just because of the strap:\ so the H1 is the first with replaceable straps. cons: only 4gb and 512mb.
that is kind of a risk:) damage can be seen few days or weeks after.
Yes but the ability to leave it on while swimming is the only reason I bought it.
I have numerous android watches that I have to remember to take off at the beach
and they are all, realistically the same thing with perhaps more memory or case/band designs.
If I leave this on powersaving mode and just use it as a watch I can swim with it lasts for
several days.
Manufacturers need to be more honest with exaggerated IP ratings, this one (so far) appears to be actually IP68.
