Hi all, does somebody has the firmware for the ZEBlaze Thor S Smartwatch. I’ve installed version Z10-KY_HFP-BT-20171122 but it does not seems to be the good one. Screen is upside down and the touchpad shifted 45°. Many thanks.
Mar 29, 2018 17:07:57 GMT 1 useivan said:
Hi all, does somebody has the firmware for the ZEBlaze Thor S Smartwatch. I've installed version Z10-KY_HFP-BT-20171122 but it does not seems to be the good one. Screen is upside down and the touchpad shifted 45°. Many thanks.
you can't use other watch firmware on this watch. ***was preloader marked when you flashed?
Yes the preloader was marked.
even though you should'nt have flashed it with firmware that is'nt it's but if you do you must'nt mark preloader. ther thor s have 2gb ram and 16gb storage, correct?
i was thinking that thor could have every firmware that has the name thor. yes it has 2 gb ram and 16gb storage. is there a place to find a firmware for this thor s watch?
i'm checking:)
Here is thor s FW donated by another member /thread/2314/thor-untested-kindly-donated-member
