Well this watch has lived up to the name.
Was sat at my desk with watch in airplane mode watch rebooted then stopped mid boot and got very hot. Hmmmmmmmmm best take this off my wrist. Trued powering of non responsive had to remove the battery. Waited for it to cool down reconnected the battery and now all it dose is stay on a black screen and heat up. Currently opened a RMA with fasttech but anyone got a fix for this or has seen it before?
Jul 16, 2018 13:56:01 GMT 1 sephiroth555999 said:
the only solution that can help is flashing the watch but for that you need the stock rom, something caused it to hit up.
Will have to see if I can get to it via USB as the screen is blank when powered on now.
well gave it a bash got it to recognise a few times but only for a few seconds then failed to format using the flash tool. I can only hope fasttech will rma it
Jul 16, 2018 21:38:10 GMT 1 sephiroth555999 said:
it does'nt have to be power on to flash it and why are u using formating? that will delete your imei. do you have the firmware for it?
Tryed a few different images and flash tools all are erroring out with different errors. Think I will build a windows 7 machine (for comparability) don’t suppose anyone has the correct firmware for the Thor pro 3g
One listed below
www.fasttech.com/products/9648130
Jul 17, 2018 17:58:04 GMT 1 sephiroth555999 said:
checking....
checking…
Thank you
checking…
ok, the firmware for the watch is on the site:)
mega.nz/#!8tBDhA6A!JrZ0XFyJxxF5yv6Sa4QshNogE0v_YBcNN4E4KyczcbI
checking…
ok, the firmware for the watch is on the site:)mega.nz/#!8tBDhA6A!JrZ0XFyJxxF5yv6Sa4QshNogE0v_YBcNN4E4KyczcbI
Turns out it was windows 10 messing me about imadged it on Windows 7 eventually so now I have a fully working watch thank you for thehelp I hope it doesn’t fall over again
